Poll on how your transmission cross member is mounted
Topic: Poll on how your transmission cross member is mounted (Read 7799 times)
July 10, 2013, 12:22:18 am »
Just curious how transmission cross member is mounted.
jaredts
Re: Poll on how your transmission cross member is mounted
July 10, 2013, 03:56:01 pm »
I didn't answer the poll because I'm not sure the stock crossmember mounting fits any of those. I have seen a lot of pictures that leads me to believe that my '83 c10 has a very common crossmember mounting. The driver's side goes under the frame and up the outside, bolting underneath and through the side. The passenger side rests on the bottom of the frame rail and bolts through the bottom. There is a bolted on "wing" that goes under the top part of the frame and bolts on there.
Your truck is a 4x4, right? Was that what you intended the poll to be for?
July 10, 2013, 09:27:16 pm »
He is talking about a 4x4 truck.
July 18, 2013, 02:21:50 am »
yeah sorry should of said 4x4. only 4 votes cmon people help me out here lol
Jason S
July 19, 2013, 06:56:26 pm »
1973 K2500
winky
July 19, 2013, 08:55:05 pm »
My 77 1500 was bolted on bottom stock looking. 84 bolted bottom. Stock a 2500 frame I had 79( I think) bolted bottom. Stock looking. All 4x4 77 350/208 79 unknown auto. 84 sm465/208
Tx_Phil
July 19, 2013, 08:56:54 pm »
I don't see a poll.
I guess it's a Tapatalk thing?
All I know is the the crossmember on my suburban is below the tail in the transmission and stretches between the frame rails. I've never looked at it close enough to know how it's attached.
July 20, 2013, 11:09:53 pm »
was talking to my buddy and he said all the 4x4s he seen where resting inside the frame rail. maybe this is more of a transmission deal?
July 20, 2013, 11:12:43 pm »
i mean if you look at this picture
the cross member has dual bolt holes for either way, i just dont understand why or when they did change this is on a 86 k5
