Author Topic: Capping the power steering system temporarily?  (Read 4040 times)
Offline craigjohnston3
« on: August 05, 2013, 04:40:41 pm »
Hello, new to the forum so not sure if this belongs here or not...
Trying to replace a borgeson self contained power steering pump on my 78 C10 with a 383 stroker. Got a new pump in but the high pressure fitting on the back of the pump is in the wrong place and hits the block rendering it useless.
My question is this: While waiting on the return to ship and the correct part to come in, can I cap my power steering lines and tie them back and drive the truck with no power steering? Or is there a possibility of damaging the steering box by doing so?
Any info will help,
Thanks.
Re: Capping the power steering system temporarily?
« Reply #1 on: August 05, 2013, 05:38:18 pm »
Many years ago we would keep the box full and looped the 2 lines together as a temporary fix when money was tight.  I went over a year that way and when I had the scratch I fixed it right.  Didn't seem to hurt the box any after the fact.  Sure was tough steering it, way worse than a manual box for sure.
Offline Engineer
« Reply #2 on: August 12, 2013, 11:35:18 am »
Loop a hose from one fitting to the other on the box. This is mostly to keep water out. Then drive it.
I don't however, recommend doing this to the pump. If the pump can't pump to the box then you need to remove the belt.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
