Author Topic: Hooking up a tach. Which wire?  (Read 11098 times)
Offline Lowhoe775
« on: August 08, 2013, 09:12:49 pm »
I got a 78 c10 with a 250 inline 6. Anyone know what color wire is the one I Need to hook up a tach. On the distributor I got (orange/peach)and two black (dark) color wires. Thanks
Re: Hooking up a tach. Which wire?
« Reply #1 on: August 09, 2013, 01:36:36 am »
dont know for sure cause something doesn't sound right, what tach do you have. do you have a engine size switch on the tach? do you have a light on the tach? i would think orange is the signal from the distrib. and the other are ground and light but make sure you are listing the right color wires ie. if one as a white stripe
Offline Lowhoe775
« Reply #2 on: August 09, 2013, 03:50:15 am »
I don't have the tAch yet but most likely it will be like a sunpro. I'm going to summit racing to get it tomorrow. Says it works with all engines
« Reply #3 on: August 09, 2013, 04:14:20 am »
ohhh i see what your question is saying thought you where saying you tach had those colors lol. on your distribitor cap it will be marked with the word tach it should be the only open plug spot on the ear. but read the top part it will say what wires go where. you dont need to tap into any wires there just put a female spade connector on a wire and it should slide in place.
« Reply #4 on: August 09, 2013, 04:20:51 am »
this should help i know its for 8 cyl but it will give you an ideal
Offline blazing816
« Reply #5 on: August 09, 2013, 08:38:58 am »
Mine was a 8 also but I just run the green wire off the tach and put a female connecter on it, pushed it on the only open spot and 'presto' working tach.
Offline sphinx
« Reply #6 on: August 11, 2013, 06:29:00 pm »
6 is same as 8.   Connect it to the "tach" it will give you a 12 volt signal to drive the tachometer.
Offline Lowhoe775
« Reply #7 on: August 12, 2013, 12:29:24 am »
Thanks to everyone that helped it worked perfect thanks. It was labeled "tach" just put a connector on the wire and it worked
Offline Engineer
« Reply #8 on: August 12, 2013, 11:39:18 am »
Your tach will most likely have a switch to select 4/6/8 cylinders. Make sure to select the correct setting or your tach will be inaccurate for the 6cyl engine. Almost all tacks come default set to 8 cylinders.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
