Author Topic: door locks are sticking (manual)  (Read 5248 times)
Offline p7387
« on: August 10, 2013, 07:21:03 pm »
87 r10
manual door locks are sticking intermittently on both doors, the symptoms are always the same, feels like a binding sensation
unable to pull up plunger
unable to turn key
unable to use latch from inside
anybody ever have this problem? is there some component i should focus on in particular?
thanks
Re: door locks are sticking (manual)
« Reply #1 on: August 10, 2013, 11:11:19 pm »
you have to take the door panel out but.. i want to say i seen this problem but while rolling down a window it would catch on the lock and lock the windows. then you wouldnt be able to unlock it till you rolled the window back up. dont remember where or what vehicle this was on but inspect the plungers rod and see if its hanging up on something. but after this happens what do you do to fix the problem?
Offline p7387
« Reply #2 on: August 11, 2013, 12:27:34 am »
after it happens i just keeping fussing with the plungers, latch or key for a few minutes and it eventually lets loose.
i plan to pull the door panel and have a go at it.
« Reply #3 on: August 11, 2013, 08:22:35 am »
When this happens, depress the outside handle button a few times and see if it stops binding. Usually cleaning and lubing the latch assembly will cure this problem.
Offline p7387
« Reply #4 on: August 12, 2013, 11:09:31 pm »
Will do
Thanks
Offline tj wand
« Reply #5 on: August 14, 2013, 12:13:46 pm »
on my 82 i gotta lean up against my passenger door and put my body weight into the door to just pop the lock up with the key. i dont keep anything in the truck so i don't lock it
Offline got2haul
« Reply #6 on: August 14, 2013, 02:16:17 pm »
I experience this occasionally with my '80 stepside.  It's frustrating when it happens, but I haven't taken the time to diagnose it.  I'll be interested to see what you find.
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
