Author Topic: 6.2 intake manifold options??  (Read 12467 times)
Offline Dirty Offio
« on: August 16, 2013, 06:19:11 pm »
Hey all,
I just read a post and someone mentioned changing out the restrictive intake for something that flows better.  They mentioned the J code intake, but are there any other manifolds that will work?  The block design looks like a BOP block, (Oldsmobile if I had to guess.) I know the engine was designed by Detroit, but is there any chance of an Olds or ?? manifold fitting?
Thanks!
Offio
Re: 6.2 intake manifold options??
« Reply #1 on: September 26, 2013, 12:13:41 am »
No chance...
Offline Edahall
« Reply #2 on: September 26, 2013, 11:15:01 pm »
Well, if you're looking to save money, you could chip out the pedestal.  Once that's done, you can plug up the hole with a cap and epoxy.  You'll end up with the poor mans J code intake manifold
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline Dirty Offio
« Reply #3 on: December 17, 2013, 11:06:38 am »
Figures!  lol.  Oh well, I will see if I can find a J code manifold!
Cheers!
