Author Topic: steel 16 inch wheels, fit 4x4 half ton  (Read 31587 times)
Offline howlinwolf
« on: September 04, 2013, 08:18:21 am »
Exactly that, what year truck would have 16 inch 6 lug, preferably steel, that would fit a 78 1/2 ton 4x4. i had a set of aluminum wheels someone gave me, but the hole for the hub was too small. They were off of a 88+.
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Re: steel 16 inch wheels, fit 4x4 half ton
« Reply #1 on: September 25, 2013, 10:47:03 pm »
Aftermarket if you want 16's
Offline Jason S
« Reply #2 on: December 03, 2013, 11:28:11 am »
According to the SPID information, my '74 K10 came from the factory with 16" 6-lug steel wheels and bright hubcaps.  When I got the truck back in the late 90's the 16" wheels were long gone.
For new wheels, Dexter wheel makes 16" 6-lug, painted steel wheels that accept the 3/4-ton hubcaps...
Offline Elpresidente
« Reply #3 on: December 04, 2013, 12:06:55 pm »
99-04 Silverado & Sierra. Mine are 16" with 6 lug bolt pattern, i'd sell you my spare set if you lived close lol
'82 Chev Scottsdale
Proud to be Canadian \m/
« Reply #4 on: December 04, 2013, 01:16:04 pm »
I used to have a set of 4.  They were on my 6 lug car trailer with 7.50x16 tube tires.  Regular dog dish hubcaps fit on them.  What I don't know is if they were tubeless rims or not.
« Reply #5 on: December 04, 2013, 07:22:51 pm »
I was thinking the 16's rims for our trucks were not tubeless?
« Reply #6 on: December 04, 2013, 07:49:34 pm »
If I remember that era, none of the 16's where tubeless.  My 72 had split rims and I went to 16.5's to go tubeless and radials...
« Last Edit: December 04, 2013, 09:23:36 pm by zieg85 »
« Reply #7 on: December 04, 2013, 08:41:24 pm »
That is what I was thinking.
Offline audrima
« Reply #8 on: December 05, 2013, 08:50:03 am »
my 16X7.25(or what ever) from my 78 3/4 ton (8 lug though.) had tubes
Offline Gusgusa1
  • Gasket
« Reply #9 on: December 13, 2013, 05:37:53 am »
Try 1984 and older. What is the diameter of the center hole?
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
« Reply #10 on: December 13, 2013, 05:53:51 am »
like gusgusa said the diameter is the problem once gm went to idf 88+ they made the center hole smaller and they wont fit
Offline 75gmck25
« Reply #11 on: December 25, 2013, 08:46:17 pm »
I have 8 lug 16" wheels with 245/75R16 tubeless tires on my '75 GMC K25.  My original wheels were split rim 16.5" with 9.50x16.5 tires.
Tubeless 16" rims with either 6 lugs or 8 lugs used to be very common in the junkyards, but I haven't looked in a while.  You usually had to pull them off one of the trucks, so it was easy to verify they would work on a square body.
Bruce
Offline howlinwolf
« Reply #12 on: December 26, 2013, 12:42:56 pm »
im not sure what the center hub size is
Offline dvdswan
« Reply #13 on: December 27, 2013, 10:20:26 am »
I beleive the older vehicles were 4" and new ones are 3".
Offline Jason S
« Reply #14 on: December 27, 2013, 07:20:12 pm »
Wheels from 1969-1987 trucks with 6-lug on 5.5" lug spacing with a 3.65" pilot (hub diameter) will interchange.
 6-lug wheels from the '50's through the '80's can work, but 16-inch wheels on 1/2-tons it seems were not as popular as the 15-inch variety.  As noted, most of these trucks came with tube tires.
Additionally: the Jeep Wagoneer, Cherokee (Full-Size) and J-10 trucks ran the same size wheels and lug patterns. I know 16" steel wheels were available on some of these models.
As for the tube versus tubeless issue, I have run tubeless tires on many 60's and 70's trucks that were originally equipped with tube type tires.  From what I've seen:  If  the wheel is in good shape and the welds are good and no major internal rust on the wheel, then there should not be any issues.
As noted above I used new Dexter wheels because I could use hubcaps and replicate the factory appearance.  There are a number of aftermarket companies (Crager and Keystone) that make 16" steel 6-lug on 5.5" lug spacing, but they are styled wheels.
Here are some photos of my Dexter Wheel 16-inch 6-lug steel wheel setup with 7.50 x 16-inch bias ply mudgrips.
Front:
Rear:
Closeup of rear, 3.65" pilot (hub) diameter:
Closeup of front:
Here are a couple of links of some wheel interchanges:
http://www.okoffroad.com/editorial-boltpattern.htm
http://adaptitusa.com/referencebook.htm
« Last Edit: December 27, 2013, 07:31:15 pm by Jason S »
