Author Topic: shaving the body of my 85 silverado  (Read 10450 times)
Offline Jason Wiechec
« on: October 01, 2013, 07:54:48 pm »
I have a 85 Silverado, I want to shave off all of the molding, drip rails and get smaller mirrors for the doors. I know that all of the side moldings are held on by adhesive accept for the bed corners but I also want to delete the molding behind the cab and on the tailgate. I would also like to get smaller door mirrors like on the 67- 72 C10 could some one suggest where I can get the mirrors and how difficult the swap would be
Re: shaving the body of my 85 silverado
« Reply #1 on: October 02, 2013, 09:01:23 am »
     I believe the store on this site is selling the earlier truck parts, check with Chris.
     Are you capable of welding and doing minor fabrication ?  If so, the mirrors should not be hard, look here http://forum.73-87chevytrucks.com/smforum/index.php/topic,18539.0.html for mirror mounting help, this is for 73 - 87's, but should give you some advice on what you need to do to mount different mirrors.
« Reply #2 on: October 02, 2013, 07:48:51 pm »
We sell 67-72 mirrors, just not in the store.  They are $49.95.
I don't have a vendor (looking for one) that sells the 73-87 small mirror, but classic industries sells them
« Reply #3 on: October 07, 2013, 08:52:23 am »
thank you for help with the mirrors guys. I still need advice on removing the molding on the back of the cab and on the tailgate
« Reply #4 on: October 08, 2013, 07:50:26 pm »
Are you wanting to know HOW to remove the trim on the cab?  The tailgate trim just unbolts but you will be left with holes.
« Reply #5 on: October 14, 2013, 02:01:55 pm »
yes I would like to remove it. it is old and looking like junk, not sure if I want it gone or replaced. was also thinking of replacing the tailgate molding just not sure where to find it
« Reply #6 on: October 15, 2013, 04:37:27 pm »
You get this figured out?
« Reply #7 on: October 16, 2013, 08:13:24 am »
I am going to keep the trim/molding behind the cab and on the tailgate because it is the most cost effective route just need to find replacement parts.
« Reply #8 on: October 16, 2013, 11:47:39 am »
How bad are you current pieces?  I don't have the cab trim except used, and I would check with Cheyenne pickup for the tailgate trim.
« Reply #9 on: October 17, 2013, 09:58:16 am »
the trim is not rusty just discolored and the coating on the Chevrolet on the tailgate trim is starting to flake off. is there a way to restore them
« Reply #10 on: October 27, 2013, 02:05:50 pm »
scuff it and clearcoat it would be and option
Offline 81_Chevy
« Reply #11 on: October 28, 2013, 11:48:23 am »
wet sanding and or scuffing with clear coat can polish up just about anything on your truck trim wise.
i redid my taillights with the wet sanding and clear coat option. it took the reverse lights from a clear yellow color to a clear white color. made a world of difference.
-Nic
