Author Topic: 700r4 No Lockup  (Read 6359 times)
Offline Boone83K10
700r4 No Lockup
« on: October 14, 2013, 03:47:20 pm »
Please read entire post..sorry it is sort of long.
About 8 months ago, I tried to take off my factory cruise control. I lost converter lockup even though I am not sure if I knew it was doing it before that. I put it back in, but the shift points changed. They went from 15,25,35 and engaged lockup at 45...... then it went to 15, 35, 50 and no lockup. I know it isn't locking because you can tap the brake pedal and the RPMs don't change.
About 2 weeks ago after messing with a bunch of wires under the dash while fixing my brake/backup light problem... it started working. Now it did get a lot cooler around then. It wasn't driven for about 2 weeks. It went back to lockup shifts I listed above.
It then went to only locking up when the truck was "cold" It would cycle a couple of times after shifting into 3 and 4 then smooth out. It would stop after braking when warmed up or if I had to engage kick down. It hasn't come back since about a week ago. There is no slipping, it shifts real good. I don't go faster than about 55-60 since 55 is the highest speed limit around here. I don't know if lockup occurs at a higher speed when it does this.
I confirmed that the brake switch is functioning. the vacuum switch is hooked to full manifold. the TV cable is adjusted just fine. Also, this truck has a swapped in 350 from 1970.. the LE9 305 is long gone. The ESC is still there but every wire is cut at firewall. I don't know if this truck was EGR bleed transmission or not. The RPO is MX0 with K34 cruise control. Vacuum diagram code is DFH which I can't find anywhere online...
Does that sound like a bad 4th gear pressure switch? Converter going out? Vacuum switch is failing? any help is appreciated.
I have this switch
It has an ORANGE wire that is hot all times. It has a WHITE wire that is hot when the brake is pressed. This plug is closest to the plunger. (I thought the brake plug was suppose to be furthest away from plunger?)
I also have a plug that has two GRAY wires into one side of the plug. There is a GRAY/BLACK wire into the other side of the plug. GRAY/BLACK is hot all the time. The two GRAY wires are HOT when the brake pedal is at rest. This plug is furthest away from plunger.
I also have this switch
It has a LIGHT BLUE and a BROWN wire running into the plug. It also has a vacuum hose out the back. This switch is to the right of the brake switch.
On the other side of the column I have this white plug.
It has a LIGHT BLUE wire, 2 WHITE wires, BROWN wire and 2 LIGHT GREEN wires.
I am wondering if things are plugged in wrong.
this pic (WHICH IS NOT FROM MY TRUCK, JUST FOUND IT ONLINE) shows the LT BLU and BROWN wiring on the same switch with the brakes. That clear plug is on the other switch with the red plunger in my truck.
Wiring diagrams show LT BLU and BROWN to brake switch with reference to stop lamp. It shows 2 GRAY and 1 GRAY/BLK to "brake switch". I assume that this means the release switch with the red plunger and not the black switch since the diagram says REF STOP LAMP for the LT BLUE and BROWN.
Do you think it will make a difference if I switch them around. Could I have switched them around when I tried to take off the cruise or maybe it got messed up when PO made the engine swap?
« Last Edit: October 14, 2013, 03:54:39 pm by Boone83K10 »
1966 Mercury Comet - Built 429 (First Car/Show Car)
1983 Chevrolet K10 - Built 350 (Winter Toy)
1992 Chevrolet Lumina Euro (Sold @ 265,000 miles)
2003 Ford Escape 4x4 - Mac Perf. Intake/Exhaust (Wifes' DD)
2007 Mercury Milan - Steeda Tuned (Summer Toy)
Offline Boone83K10
Re: 700r4 No Lockup
« Reply #1 on: October 14, 2013, 06:44:57 pm »
After reading over my posts, I noticed and remembered that I did not test the LT BLUE and BROWN wires. Gave them a test and both were hot with pedal pressed and at rest. So the switch must not be doing its job. BTW, they plugs don't interchange.
I took off the switch and you can open it up. The contacts inside were not touching (just barely apart) when the plunger was pressed in. This probably explained why it worked when it was cold outside. metal would shrink and they would touch, then go away when I would heat up the inside of the cab.
I cleaned up the contacts, bent them some and put it back in the truck. I cleaned the brake switch too while I was at it. I drove around for about 15 minutes and it works like a charm. WOOHOO...
and since no one responded to this...yay to me for figuring it out on my own.
Re: 700r4 No Lockup
« Reply #2 on: October 14, 2013, 06:58:15 pm »
Well you've got to give us a chance to see your post to respond. Sounds like you talked yourself through it.
Offline Boone83K10
Re: 700r4 No Lockup
« Reply #3 on: October 14, 2013, 07:06:21 pm »
yeah I know. I didn't want to sound negative. I just glad it's working now. Don't need a burnt transmission. I wanted to get it fixed before the snow gets here and it dumped a foot on Halloween last year.
