Author Topic: oil gauge issue  (Read 4107 times)
Offline jrbarrie83
oil gauge issue
« on: October 18, 2013, 09:26:08 pm »
Hey all,
I replaced the incorrect gauges in my '83 Silverado with another set I bought recently at a swap meet.  (When I bought the truck, it had aftermarket manual gauges, and all I had to replace them with were a set of the earlier style my dad had lying around.)  The gauge that was in place had been working prior to removal.  When I put the "new" cluster in, everything seemed to go to it's correct initial position, except the oil pressure gauge.  It immediately went all the way up (pointing to the 3 o'clock position).  What could be the problem?  Is it just a lack of current from one of the connections?  I figured it has to be either the connection at the gauge itself or the back of the cluster.  Since the previous gauge worked, I figure one of these has to be the answer, but I had other things I had to get done this evening and had to leave it for now.
Thanks for the input!
Jim
Re: oil gauge issue
« Reply #1 on: October 27, 2013, 02:00:37 pm »
what year truck and what year previous and current cluster?  Does the sender match the new cluster?
Offline jrbarrie83
Re: oil gauge issue
« Reply #2 on: October 28, 2013, 09:38:27 am »
Thanks for getting back to me bud.  I actually figured it out - must have been just a connection problem.  As soon as I started to remove the screw holding the gauge in, it went back down to the lowest reading and has been working fine since.
