Author Topic: rear drum locking up  (Read 7335 times)
Offline jarhead76
  • 76 Silverado K20 camper special
« on: October 21, 2013, 07:32:04 pm »
the passenger side rear drum is locking up when the truck sit for a descent amount of time (at work or over night) with the parking break set.  i rebuilt the drums in late Auguste and this did not start till about 2-3 weeks ago. its not every time but is definitely becoming more frequent. i opened it up and everything looked fine. any ideas on where to begin to fined the problem.
90 suburban V1500
Offline DnStClr
Re: rear drum locking up
« Reply #1 on: October 23, 2013, 12:53:46 am »
Could the adjuster be set too tight? That would be the simplest thing to check.
Don
87 Chevy Silverado
Offline jarhead76
« Reply #2 on: October 23, 2013, 09:20:29 pm »
the drum breaks are self adjusting and i was bale to pull the drum off. i think the cylinders need to be replaced. or the parking break cable is damaged.
90 suburban V1500
Offline 454Man
  • Why Race?
« Reply #3 on: October 23, 2013, 09:51:55 pm »
Maybe you have air I'm the line. That's usually the cause. Hope this helps.
« Reply #4 on: October 23, 2013, 11:57:57 pm »
sound just like a sticking parking brake. i dont know a fix but i would try to find where its sticking idk maybe springs???
Offline jarhead76
« Reply #5 on: October 24, 2013, 06:47:23 pm »
its only the passenger side and will unlock is i back up about a foot.
90 suburban V1500
Offline CanadianC10
« Reply #6 on: October 24, 2013, 07:11:59 pm »
Wheel cylinders have nothing to do with it, nor do the lines it is a mechanical cable break , there are 3 cables on the truck, I'd say the passenger side cable is seizing up
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
« Reply #7 on: October 24, 2013, 10:49:35 pm »
we're on the same page ;-)
Offline jarhead76
« Reply #8 on: October 28, 2013, 06:13:53 pm »
well i fixed it the exhaust bracket broke and was pushing down of the break cable not allowing it to fully release.
90 suburban V1500
« Reply #9 on: October 29, 2013, 11:21:08 pm »
lol something simple.
