Author Topic: Wiring up power windows and door locks  (Read 183988 times)
Offline nlauffer
Re: Wiring up power windows and door locks
« Reply #15 on: October 31, 2013, 04:26:33 pm »
I went across the street to Napa to look up some relays and sockets and these are what I found.
Echlin Brand
Relay - AR143  $13 each
Socket - EC23  $13 each
This puts you just over $100 plus some wire and a fuse to accomplish this.  I think while I have my truck disassembled I'm gonna wire this up.
Offline nlauffer
« Reply #17 on: October 31, 2013, 08:57:55 pm »
This is why I posted my find. I was hoping someone else would post other options. Does anyone know the quality of the above relays?
Offline 75chevyk20
« Reply #18 on: November 05, 2013, 11:47:47 pm »
Thanks for all the help I appreciate it. As I read on I'm starting to get a bit confused, but this weekend I think I'll just dive into it and see what I can figure out with those diagrams. It's a little embarrassing I am starting to get lost with what you guys are talking about because I am a mechanic but electrical has never been my strong suite.  Do you think those relays on eBay are decent ones? I think for that price I will order them and if you guys think the relays are junk I will just use the sockets and buy good relays.
Offline 1982 Daily Driver
« Reply #19 on: November 19, 2013, 06:03:13 pm »
Just finished wiring up the relays for my windows. It is amazing how much better they work. Truly unbelievable.
Offline nlauffer
« Reply #20 on: November 19, 2013, 08:35:14 pm »
Would you post some pics. I am curious to see how you mounted the relays and where you spliced in the wires
Offline frotosride
    • WFO CONCEPTS
« Reply #21 on: November 20, 2013, 04:33:12 pm »
I wanted to keep the factory style connectors inside the switch connector so I just used butt connectors and solder. Once re wrapped it looks factory
Offline frotosride
    • WFO CONCEPTS
« Reply #22 on: November 20, 2013, 05:09:50 pm »
Wires rerouted...
Offline blazing816
« Reply #23 on: November 21, 2013, 10:52:09 am »
Bosch is likely the best ones to get and make sure that are 5-pin.
Just so you know Bosch relays got bought out by Tyco if I am not mistaken. So I found these which are Tyco/Bosch and are a good price for 5 relays and harnesses.
http://www.ebay.com/itm/5-PACK-Tyco-Bosch-Relays-SPDT-12-Volt-with-Socket-/190974247644?pt=LH_DefaultDomain_0&hash=item2c76f3c2dc
Offline frotosride
    • WFO CONCEPTS
« Reply #24 on: December 01, 2013, 06:18:11 pm »
here's how I mounted the relays. I cut out an aluminum plate and drilled holes to mount them. from there I just used Velcro to mount them to the air handler.
Offline frotosride
    • WFO CONCEPTS
« Reply #25 on: December 01, 2013, 06:19:26 pm »
plate and plate with Velcro and relays attached
Offline frotosride
    • WFO CONCEPTS
« Reply #26 on: December 01, 2013, 06:21:19 pm »
mounted on right side of air handler. A little warpping and loom and it will look good.
Offline jpatters13
    • 74' Chevy Truck Project
« Reply #27 on: April 11, 2014, 07:50:42 pm »
I am in the middle of implementing this wiring configuration.  I have only one question. Am I reading the diagram correct that terminals 87A and 85 on all four relays are grounded?
84 Silverado K10
74 Custom Deluxe C10
« Reply #28 on: April 11, 2014, 08:50:29 pm »
     Post a link to what diagram you are referring to please.
Offline bd
« Reply #29 on: April 11, 2014, 09:42:32 pm »
Correct.  But, there is a caveat:  Are the relays you're using surge clamped with a diode internally connected between terminals 85 and 86?
