Author Topic: disc brake kit with 5 on 5 lug pattern  (Read 5667 times)
Offline 87R10383
« on: October 29, 2013, 08:57:27 pm »
I'm swapping in a ford 9 inch under the rear of my '87 r10, and I'm looking at disc brake conversion kits. Does somebody sell an axle and disc brake kit to retain the 5 on 5 lug pattern? All of the kits I've found so far use either the 5 on 4 3/4 or 5 on 5 1/2 patterns. I can have axles made and drill the rotors to 5 on 5, but I'd like to avoid that if possible. I don't mind having two different lug patterns on the truck, but finding wheels that are made in both patterns is a little tricky.
Thanks in advance
Matt
Re: disc brake kit with 5 on 5 lug pattern
« Reply #1 on: October 29, 2013, 09:10:12 pm »
Not sure about a kit for a Ford axle with the 5 on 5 Chevy lug pattern, but Astro vans used 5 on 5 bolt pattern if you need a disc to make a set.
Offline pitbull2332
« Reply #2 on: November 28, 2013, 05:44:49 pm »
I am doing this on my 1986 C-10 now. I used a allstall performance kit. It does not have a ebrake, But does have 5x5, bolt pattern
« Reply #3 on: November 28, 2013, 06:15:30 pm »
What's the lug pattern on the axles you have? You have a lot of options with wheel adapters.
Offline skinu
« Reply #4 on: December 13, 2013, 08:09:48 am »
no do it right !! I built mine using off the shelf items and made my own brackets ,understand your brake system function and even with any kit theres a lot that wont come with it but its all there you just need to mod it yourself. I got the recipe for them done these since 84 and its a diff you will love, a lil work will save you $$$ I do my for under 300 ,dig some info out 4u
