Author Topic: Brake problems  (Read 7419 times)
Offline dbrister54
Brake problems
« on: November 16, 2013, 05:45:19 pm »
Alright guys got a problem. I have a 1979 big ten and the problem is with my brakes when I hit the brake pedal hard I have brakes and it stops but if I slowly apply the brakes it goes all the way to the floor and the brakes don't engage I've change the booster but not the cylinder, is the cylinder the problem? And before u ask I did bleed the brakes. Thanks for any help
Re: Brake problems
« Reply #1 on: November 16, 2013, 05:48:11 pm »
Sounds like the master cylinder to me
Re: Brake problems
« Reply #2 on: November 16, 2013, 06:45:21 pm »
X2
When you replace the M/C, bench bleed it first and then give the whole system a good flushing with fresh DOT 3/4 fluid.  Be sure to check the wheel cylinders for weeping, too.
Offline DuckAholic1
Re: Brake problems
« Reply #3 on: November 17, 2013, 01:35:38 am »
What does "weeping" mean?? :-\
Re: Brake problems
« Reply #4 on: November 17, 2013, 06:13:48 am »
The rear wheel cylinders have moist dust boots.  When they start to weep brake dust will collect around the dust boots.
Re: Brake problems
« Reply #5 on: November 17, 2013, 06:26:34 am »
weep=a small leak
Offline DuckAholic1
Re: Brake problems
« Reply #6 on: November 17, 2013, 04:44:01 pm »
Oohh I get it!!! Silly me. I new that!! ;D :P
