Author Topic: Throttle Body housing..Help!!!  (Read 8494 times)
Offline DuckAholic1
« on: November 18, 2013, 07:03:16 pm »
My truck: 87 5.7 TBI 700r4.
Does anyone know were I can find a new or rebiult Throttle body housing???
Offline frotosride
    • WFO CONCEPTS
Re: Throttle Body housing..Help!!!
« Reply #1 on: November 18, 2013, 08:25:55 pm »
the only place that I can think of that you can order a remaned TBI off the top of my head is Rockauto. It's going to run you 290 something and the you wil get a $50 core charge back. there are a lit of cheaper options if you want to spend the time to rebuild it yourself.
Offline DuckAholic1
« Reply #2 on: November 18, 2013, 08:40:27 pm »
Thanks frotosride!!
The reason I ask is that the only thing I need is the actual housing contaning the butterflies. I have a sticky throttle whitch I have pinpointed down to those. Do you know if they can be rebuilt?
Also, has anyone ever heard of throttlebodyinjection.com??
They have one on there site for $98 + shipping. Does this sound good.
I have searched the junkyards in my area with no luck!
Offline rich weyand
« Reply #3 on: November 18, 2013, 08:56:15 pm »
There's a bunch of them on car-part.com, the junkyard search site.  Going rate for 1987/5.7l seems to be about $125.
Offline DuckAholic1
« Reply #4 on: November 18, 2013, 09:00:27 pm »
I just thought of another question! The numbers on the front of the housing is the actual model # correct??  Are there years that are interchangeable with little to no mod. Or is it best to find the exact same model # as mine.???
« Last Edit: November 18, 2013, 09:04:31 pm by DuckAholic1 »
« Reply #5 on: November 18, 2013, 09:02:16 pm »
There is a step by step TBI rebuild I posted in the Tech section here, the kit is less than $40 if your injectors are good...
http://forum.73-87chevytrucks.com/smforum/index.php?topic=24770.0
Offline DuckAholic1
« Reply #6 on: November 18, 2013, 09:16:02 pm »
Thanks capt!!! I will definitely use your link when I rebuild. I am just wondering if this will take care of the shaft going through the housing? (the one with the butterflies attached)
« Reply #7 on: November 18, 2013, 09:35:38 pm »
What is wrong with the Shaft?  If it is loose you will need to put bushings in it...
Never used this place they just have a kit.  http://www.throttleshaftrepair.com/
Offline DuckAholic1
« Reply #8 on: November 18, 2013, 09:54:30 pm »
I am not sure if anything is "wrong " with the shaft. It seams to be the origin of the throttle sticking. This may or may not make much sense to ya but I am trying to explain it best I can.
« Reply #9 on: November 18, 2013, 10:06:17 pm »
Is it sticking open?
Offline DuckAholic1
« Reply #10 on: November 18, 2013, 10:24:36 pm »
No, it sticks from closed position. once it is open it seams to feel fine. I did have a mechanic look at it, and He thinks the bushings in shaft are worn. Although it feels to me like the actual butterflies are sticking to the wall.
« Reply #11 on: November 19, 2013, 08:30:07 am »
The TBI throttle shaft is not bushed from the factory.  That is to say, the throttle shaft is supported directly in the TBI body without bushings.  The TBI housing is very soft compared to the steel throttle shaft, so the housing manifests the majority of any wear.  As the TBI body wears, the shaft fit in the housing gets sloppy and the shaft begins to move sideways - it's no longer held in proper alignment.  That forces the throttle plates off-center from their bores; the plates 'stick' around their circumference as they bind against one side of the throttle bores.  Bushing the throttle shaft just realigns the shaft in the housing and recenters the plates in their bores, so they won't bind and cause the symptoms you're experiencing.
Offline nlauffer
« Reply #12 on: November 19, 2013, 09:30:21 am »
Looking on Rockauto, you can get a rebuilt TBI unit for $250 (+ $50 core).  If you get a rebuild kit and the bushing kit listed above, you will be more $ than the rebuilt, however there is a chance you could sell the bushing kit once done with yours.
Offline DuckAholic1
« Reply #13 on: November 19, 2013, 12:57:38 pm »
Thanks a lot for all the input!! I think I'll go ahead and order a Housing from Throttlebodyinjection.com @ $98 + shipping. I will let you all know how it goes.
Thanks again!!!
