Members Rides
1986 c10 rebuid
Topic: 1986 c10 rebuid (Read 25920 times)
pitbull2332
1986 c10 rebuid
December 03, 2013, 06:42:37 pm »
I bought this truck in 1997 from my grandfather. Je was the original owner. Did a rebuild on it when i was 18 to get where it is now. Truck was a lot of fun and i had a blast with it. I had it tucked away in storage fir the last 5 years and have finally had the time and money to take it to the next step. I current state she would run 12.20 to 12.30 1/4 times. Hoping to drive it on street and run no faster than 11.50s i do not want to cage it
pitbull2332
Re: 1986 c10 rebuid
December 03, 2013, 06:53:50 pm »
So i want to drop a little weight and also move some around a little bit on the truck. Also plan on installing a 377 th400 with a break and a 4500 stahl. Going to convert motor to e 85 to save a little coin on fuel. Went with a ladder rear suspension with coil overs and a currie 9 rear. Going to run a set of 32x17.50 et streets on it
pitbull2332
Re: 1986 c10 rebuid
December 03, 2013, 06:55:31 pm »
This is my allstar rear disc setup worked out nice
pitbull2332
Re: 1986 c10 rebuid
December 03, 2013, 06:58:54 pm »
And here is current state. Moving under her own power I still have a ton to do it will be a long winter
Re: 1986 c10 rebuid
December 04, 2013, 07:41:29 pm »
Nice work.
mikek20
Re: 1986 c10 rebuid
December 04, 2013, 08:34:14 pm »
I like it. Keep us updated as you progress. Good work so far
diggerdan11
Re: 1986 c10 rebuid
December 05, 2013, 11:16:31 am »
Very Nice. Im excited to see more progress.
1977 K20 Silverado Camper Special
1969 Chevy C20 (currently in a million pieces)
1969 Chevelle Malibu
2010 BMW 335xi
2007 Yukon Denali
pitbull2332
Re: 1986 c10 rebuid
December 06, 2013, 08:45:59 pm »
Well i have the fuel cell mounted, and fuel pump/filter mounted. Tore truck back apart and coated the frame. Hope to tear down the rear end this week and start the final assembly of the rear next weekend have all the fuel and brake lines made so in theory should go back together fairly smooth
pitbull2332
Re: 1986 c10 rebuid
January 17, 2014, 07:01:22 pm »
pitbull2332
Re: 1986 c10 rebuid
January 17, 2014, 07:04:28 pm »
Got the rear end all back together fuel system all plumbed up. Rear wiring complete. Motor pulled all old fuel and brake lines out. Starting to mock up new motor and trans mounts. And work on the front end rebuild.
bake74
Re: 1986 c10 rebuid
January 17, 2014, 08:16:28 pm »
Nice progress, are you going to run a bed or not ?
74 k10, 77k10 Tom
pitbull2332
Re: 1986 c10 rebuid
January 17, 2014, 10:05:04 pm »
Yes i will run the bed. Have a little more welding to do on the wheel wells to finish up still begore i set it back on. Just widened the original ones with another set. Looks good. Just cant haul a 4' sheet of plywood anymore lol
dvdswan
Re: 1986 c10 rebuid
January 17, 2014, 10:42:14 pm »
nice progress.
Dave
78 K10 Stepside
http://s36.photobucket.com/user/dvdswan/story/10553#
Skyshadow
Re: 1986 c10 rebuid
January 19, 2014, 04:04:26 pm »
NICE BUILD! love the coilover set up, the battery all the way in the rear on the pass. side, the fat ass tires and that diff with discs is dang mean looking. Is that a fiberglass mock up block? if so, freaking gnarly. Can't wait to see more.
pitbull2332
Re: 1986 c10 rebuid
January 19, 2014, 08:53:40 pm »
It is a fiberglass block makes fabing a whole lot easier. finished up motor mounts, fuel lines and mounted the regulator. Need my new a arms and should come together fast. hope to have running in about 6 weeks or so.
Members Rides
1986 c10 rebuid
