4 Wheel Drives
14 bolt gm Detroit lockers
Topic: 14 bolt gm Detroit lockers (Read 16599 times)
moats31
Re: 14 bolt gm Detroit lockers
Reply #15 on:
December 21, 2013, 06:26:08 pm »
We'll they came out of a 79 1 ton so they shouldn't be 9.5
Sent from my iPhone using
Tapatalk
Reply #16 on:
December 21, 2013, 10:56:06 pm »
ff will have 8 bolts on the hub
Engineer
Reply #17 on:
December 22, 2013, 05:49:05 pm »
The '79 1-ton should have had a Dana60/GM 14-bolt in it.
A '79 3/4-ton should have had a GM Corporate 10-bolt in the front, 14-bolt FF rear.
By 1979 GM had totally quit using the Dana44 front.
Can you post pics?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
moats31
Reply #18 on:
December 23, 2013, 11:57:48 am »
It's got the 10bolt and 14 ff. so it was a 3/4 ton
Tapatalk
moats31
Reply #19 on:
December 23, 2013, 11:59:27 am »
That's my rear.
Tapatalk
dvdswan
Reply #20 on:
December 23, 2013, 12:36:02 pm »
I hope you are not driving on that...
Dave
78 K10 Stepside
http://s36.photobucket.com/user/dvdswan/story/10553#
moats31
Reply #21 on:
December 24, 2013, 06:41:01 am »
Nope. I've got the axels all tore down for a rebuild. I'm guessing you saw the lug nuts!! Haha
Tapatalk
Reply #22 on:
December 24, 2013, 02:01:09 pm »
I was thinking the same thing
moats31
Reply #23 on:
December 24, 2013, 03:55:17 pm »
How do can I tell the diffrence from a locker and a standard housing
Tapatalk
dvdswan
Reply #24 on:
December 24, 2013, 10:33:49 pm »
if its in the vehicle, off the ground and the d/line is connected, you can spin one drum/tire and the other tire will spin - in the same direction it has a locking device: LSD or locker - in the opposite direction an open differential. note: a bad LSD will act like an open diff as well.
if its out of the vehicle you may need to unbolt the cover.
here's a good read for you...
http://www.fourwheeler.com/how-to/transmission-drivetrain/131-0605-gm-14-bolt-axle-rebuild-parts/
Dave
78 K10 Stepside
4 Wheel Drives
