Author Topic: Pivot Shaft  (Read 3693 times)
Offline Tazman
Pivot Shaft
« on: December 23, 2013, 01:24:59 pm »
The rubber bushings on the lower pivot shafts are starting to make noise when they dry out.White lithium grease does the job till it rains,but I know this is just a band aid.I know the rubber bushings will need replacing but my question is this.Should I replace the shaft at the same time and will both upper and lower need to be done,or just the lower.
Thanks
God BLESS AMERICA
Offline dvdswan
Re: Pivot Shaft
« Reply #1 on: December 23, 2013, 01:50:32 pm »
IMO, anti-sieze works better than lithium grease.
