Author Topic: Cab leans towards the driver side- need new cab bushings?  (Read 6395 times)
Offline ScottD
  • 1985 C-10
« on: December 24, 2013, 12:11:27 pm »
My first post.... :).  I recently purchased a 85 C10 in very good condition.  The cab and box lean 1" lower towards the driver side and it really bugs me.  I lowered the truck the summer and the lean is the same, so that tells me it that it must be the bushings.  I was able to shim the box so its much closer, but the cab is still sagging.  Most of the posts I read recommend replacing the cab bushings, but they don't get into detail on how to do it.  Is this a DIY job if your an average mechanic?  If so, can someone tell me where the bushings are and how to remove and replace them? I found some replacements at Classic Industries, so are they decent or should I consider Energy models?  Any help or advice would be much appreciated.
Re: Cab leans towards the driver side- need new cab bushings?
« Reply #1 on: December 24, 2013, 02:11:14 pm »
Check the cab bushings/mounts and check for spring fatigue.
« Reply #2 on: December 24, 2013, 03:00:28 pm »
I would really look closely at the left (drivers side) coil spring.  My 82 I had that same lean going on, I found a 1/2 coil broken at the top where it wasn't easily seen.
« Reply #3 on: December 25, 2013, 08:07:05 am »
It's more typical to have fatigued rear leaf springs which causes the lean/twist. You can measure from a fixed point on the top of the spring to the frame for a quick check from side to side. Just ensure its on the same lateral plane
Offline 75gmck25
« Reply #4 on: January 21, 2014, 04:29:43 am »
Once you break the bolts loose (they may be rusted), cab bushings are fairly easy to replace.  I did mine one at a time in the driveway with only some wood blocks and a small hydraulic jack to lift up the cab on one side at a time.   however, there are two bushings in the front behind the bumper where the bolts are hard to reach. I ended up buying a special box end wrench set at Lowes that gave me the right clearance.
I used poly bushings instead of stock rubber, and found that the poly bushings squeak quite a bit in normal driving as the cab moves.  Some other brands of poly bushings are graphite-impregnated, which probably reduces the squeaking.
Bruce
Offline Terryr85
« Reply #5 on: January 25, 2014, 01:55:22 pm »
If you use the energy poly bushings you still use the stock upper cup with the sleeve? When I did mine I lost those and just used the bushings and supplied washers but I need to go back in there and do something because I have a driver side sag and a lil pop when turning right
73 K20 RC/LB, D60, 14bolt, 5.3l, NV4500
