Author Topic: Electric Fans  (Read 6384 times)
Offline kodalee
Electric Fans
« on: January 10, 2014, 04:26:06 pm »
I have an 85 K10 and I was wanting to put the dual electric fans out of a ford Taurus. I was wondering how i would go about wiring them to a toggle switch.
Offline dvdswan
Re: Electric Fans
« Reply #1 on: January 10, 2014, 04:58:09 pm »
why are you not using a temp sensor and AC (if you have it)?
Offline Mtrhd329
Re: Electric Fans
« Reply #2 on: February 13, 2014, 09:46:26 pm »
This drawing would work but the 30a fuse on the fans ground leg should be moved to within 6-8" of the positive battery connection feeding the fans positive leg.
Sent from my SPH-L710 using Tapatalk
Re: Electric Fans
« Reply #3 on: February 14, 2014, 07:00:49 pm »
Agreed - Not a fan of this way.
Offline rich weyand
Re: Electric Fans
« Reply #4 on: February 14, 2014, 07:05:20 pm »
The Flex-a-lite 31149 adjustable-temperature fan controller is about 40% of list on Amazon.  Comes with everything you need, and has a connection for a toggle switch if you want that as well.  It gets good reviews.  That's what I will be using as soon as the pretty brown truck brings it.
Offline dvdswan
Re: Electric Fans
« Reply #5 on: February 18, 2014, 12:56:57 pm »
thanks for catching that.  I hadn't noticed that until you said something.  i have to agree, fuses go on the positive side.
