Author Topic: C1500 points and shoots at slightest twitch of wheel - cant speed safely  (Read 4252 times)
Offline old gyal
I stuck in a mild 355 in my 1986 C1500 2WD (in place of the 4.3V6) plus a TH350C  and 4:56 gears in back
New power is on tap now but truck has a tendency to be twitchy at the wheel - truck gets bouncy and always feels like I am correcting left and right of center when the truck is on the go to keep my heading straight  - very unnerving to try any bursts of speed
Feels like its on knife edge - any slight turns cause immediate over compensating body roll ( or is it "yaw" )
I have done new shocks all around , 275 60-15 all around on stock wheels , the steering shaft coupler was replaced
admittedly I only did basic replacement of the worst/busted control arm bushings
Where do I go from here to get some more confidence in the truck going straight and to STOP TWERKING under power
Offline old gyal
Re: C1500 points and shoots at slightest twitch of wheel - cant speed safely
« Reply #2 on: January 11, 2014, 07:59:30 am »
Have you had the front end aligned?  Your description sounds like it has a Toe-in condition coupled with + caster
« Reply #3 on: January 11, 2014, 08:15:33 am »
I want to see it twerk  ;)
Check the front end thoroughly. Do a dry park check of the front end as well (wheels on the ground, rock the steering back and forth while observing for unwanted movement) typical points of common issue are frame flex/movement from loose rivets, cracked frame, faulty front end components, loose wheel bearings, etc. After you fix any issues as Zieg said... get an alignment but go to a real alignment shop.
Offline rich weyand
« Reply #4 on: January 11, 2014, 09:40:29 am »
Check ball joints, too.
