Author Topic: Converting from AC to Non-AC ??  (Read 17111 times)
Offline mcintyrederek
  • Rookie
« on: January 23, 2014, 09:24:38 pm »
Hi,
1986 C-10 Silverado. Came with AC, but compressor locked up and holes in evaporator and condenser coil, so took it all off.  All hoses, electrical, etc, have been removed.  All, but the evaporator coil.  Should I mess with it or leave it in there?  I took the little thermal resistor speed control thingy out that controls the blower motor speed and looked at the evaporator coil and it's pretty clean.  If I took the coil out, I'd still be stuck with this big bulge looking thing which I really don't like.  Is there any way to remove this altogether and purchase some sort of aftermarket assembly that hooks the output of the blower into the interior ductwork?  Perhaps a junkyard find?  Or should I just leave it alone?
See pic.
1986 C-10 Silverado 350 CI 260 HP, Edelbrock 1405, TH400, 2.73's - rescued from the junkyard - Farm Truck, daily driver!
Offline Hinkv10
Re: Converting from AC to Non-AC ??
« Reply #1 on: January 24, 2014, 10:19:08 am »
My ac was shot when I got my truck a year ago. I don't have any pics but I bought the evaporator eliminator from classic industries for about $150 bucks. It does clean up the engine bay a bit but it is made of fiberglass.
Offline MANCHU1-9IN
  • LINT LICKER!
« Reply #2 on: January 24, 2014, 11:39:23 am »
I am also interested in this. Do you have a part number for the eliminator kit Hinkv10? I'm having trouble finding it.
"Attitude at Altitude"
2007 Silverado NNBS RCSB 4.8 LT's - UDP's - CAI - P&P TB - Vette servo - BBP tune ~ embarrassingly slow
85 K10 RCSB - 5.3l/4L80 swap - 799 heads - PAC1218's - 206/212 .553/.561 112+2.5 - BP Automotive harness - Coming together..
Offline Hinkv10
« Reply #3 on: January 24, 2014, 03:44:54 pm »
I found it at classic industries but there website sucks. Type in your make and year and go to the ac/heat section. Don't use the search feature, u won't find it. It's part number 14446.
« Reply #4 on: January 27, 2014, 09:52:17 pm »
I am guessing you want to keep the heater in there....
http://acdelete.com/pages/73-90_Truck.htm
Offline dvdswan
« Reply #5 on: January 28, 2014, 12:44:05 pm »
interesting, I'm wanting to install AC in my truck.
  • Rookie
« Reply #6 on: January 31, 2014, 09:15:54 pm »
Thanks for the replies and info.  I took the evaporator coil out and giving the blower and heater a good clean up.  I'll check that web site.
  • Rookie
« Reply #7 on: February 02, 2014, 06:55:06 am »
If I found a similar model at the junkyard that came from the factory WITHOUT A/C, will that blower housing and fiberglass duct and all fit and bolt up to the same spot that mine did with the factory A/C coil?  I am guessing the firewall and blower mounting positions would all be the same, the difference would only be that blower housing.  See pic.
« Reply #8 on: February 02, 2014, 07:28:17 am »
Firewall is completely different, you will have some patchwork to do
http://forum.73-87chevytrucks.com/smforum/index.php?topic=21690.15 is what you will have to do
« Last Edit: February 02, 2014, 07:34:05 am by zieg85 »
« Reply #9 on: February 03, 2014, 09:25:52 pm »
Ditto on above.  Nothing is the same on the AC vs non-AC
