Author Topic: trans and transfer case he  (Read 7323 times)
Offline 2tone4by
« on: January 28, 2014, 03:32:09 pm »
Looking to put a sm365 trans in my 78 4x4 truck. It now has a 3 speed on the tree, of which parts are pretty non-existent. I have located a couple of the 365's, but they are for  2 wheel drive. Anyone know what would need to be done to make one of these work for me.....thanks the 365 is the four speed with the granny low.....
Offline dvdswan
Re: trans and transfer case he
« Reply #1 on: January 28, 2014, 03:44:05 pm »
I think you're meaning the SM465.
« Reply #2 on: January 29, 2014, 08:25:34 am »
     What transmission do you have now ?  Is it standard or automatic ?  The SM465 are pretty common transmissions, a lot of junk yards should have them.
Offline 2tone4by
« Reply #3 on: January 29, 2014, 11:53:47 am »
it is a three speed  Tremec that is hooked to a np205. Not much info out there on this trans, but I have an old Chiltons that shows it as a 77 mm in it diagram of the trans. The 2 wheel drive sm465 are pretty common around here, but not the 4 wheel drive, therefore my original question.
« Reply #4 on: January 29, 2014, 11:51:39 pm »
you would need a output shaft from a sm465 that is all ready 4x4 and mated to a 205 that is like yours. the sm645 4x2 uses only a 35 spline output shaft. while the 4x4 uses a 10 spline  (older) and a 32(newer) in 78 is when sm made the change so you should be looking for a 10 spline 205 they came off the sm465 i wana say its the only 10 spline 205 that you could use.
so lets round that up, first get your 4x2 sm465 then find a sm465 take them both completely apart swap shafts then find a adapter plate for the sm465 and np205 then find a np205 that came off a sm465 4x4. but if you find a sm465 4x4 with a np205 you should just skip everything i just said and use the sm465 4x4 with np 205
Offline Greybeard
« Reply #5 on: January 30, 2014, 12:45:51 am »
LOL I agree...
To make life a little easier, find a 1980 donor truck, it'll have everything you want. The 205 was reputedly the only t-case used that year.
The adapter housing and the adapter sleeve are key here. They used to make a hybrid a coupler that was fine spline on one end and coarse on the other.  But I believe a custom adapter housing was needed because it was longer due to machining restrictions.  ORD still has both of them if you want to buy new but they also have used a-housings.  http://www.offroaddesign.com/catalog/transfercaseparts.htm
« Reply #6 on: February 03, 2014, 10:11:42 pm »
Finding a donor 1980 truck that is in a salvage yard that still has the SM465/NP205 would be a feat also, I would look for a SM465/NP205 Donor.
Offline winky
« Reply #7 on: February 04, 2014, 06:31:16 pm »
LOL I agree...
OORRRRRRR find an 85 it'll have the hydraulic clutch setup ;) that's what i did for my truck. no routine adjusting needed
