Author Topic: 1979 C10 Valve Seal Question  (Read 2769 times)
Offline brandon.michaels
« on: February 02, 2014, 10:35:48 pm »
What size valve seals should i get for my 350? any brands that you guys prefer? Thank you, -Brandon
Re: 1979 C10 Valve Seal Question
« Reply #1 on: February 02, 2014, 11:27:58 pm »
The following should work for you...
...You can use Felpro Viton Positive-Stop valve stem seals, which are effective and 'do not require machining' of the valve guide boss, or you can use Teflon Positive-Stop valve stem seals that 'require machining' of the valve guide boss.  For an otherwise stock configuration, the Viton seals are preferred and cost less to install.
