Author Topic: no lift or 2 inch lift and tire size  (Read 6593 times)
Offline DJ1987
« on: February 07, 2014, 09:24:11 pm »
just curious what the biggest tire set up I can run without lifting it is.  Guy at the store told me 31 x 10.5.  I am also wondering if I lift it a couple inches what my options are.  I'd like to get to 12 or 12.5 wide.  I'm new to this, always a Mustang Cobra guy but trying to learn the basics.   :)
Re: no lift or 2 inch lift and tire size
« Reply #1 on: February 07, 2014, 10:54:44 pm »
things to think about. what type of truck
GVWR
how you plan on using the truck
back spacing of the rims
Offline DJ1987
« Reply #2 on: February 09, 2014, 02:39:44 pm »
V10 87 custom deluxe 4x4.  GVWR?  I want a pre-runner look without the front plate etc.  Just a fast 4x4.  I was actually thinking of dropping it 2 inches and running with 31x12 tires to get the look I'm aiming for.
« Reply #3 on: February 09, 2014, 06:22:34 pm »
     GVWR= Gross Vehicle Weight Rating
   Knowing and understanding GVWR,  the maximum weight of passengers and cargo you can safely carry in your truck.  If you are going to tow something.  GVWR is the total combined weight of truck and trailer, including all passengers, fuel, fluids and cargo. GVWR is constant and does not change, regardless of what you tow. It’s engineered in when the vehicle is manufactured.
« Reply #4 on: February 10, 2014, 10:46:44 pm »
gvwr the higher rating the more springs/lift it will have. since its only a v10 it wont be that high, if you want a fast 4x4 dont change the tire size cause it will slow your take off down if you want to drop it 2" forget about 31s
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: February 27, 2014, 03:24:16 pm »
stock 4x4 you can def get at least 32's on it, 31's if going offroad with mind to articulation.  2" lift and you can have 33's
Offline Gusgusa1
  • Gasket
« Reply #6 on: June 28, 2014, 09:49:48 am »
Pre-runner ? Why not just get a pre runner.
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
