Performance
Carter p4070 elec fuel pump question?
Topic: Carter p4070 elec fuel pump question? (Read 6827 times)
ian75c10
February 20, 2014, 05:35:12 pm »
I just bought this pump to put on my 75 c10 w/ 327 in it. PO had a cheapy that I didn't want to wait for it to go out. I have used this pump before on a f100 with great results. My problem is for some reason I am getting 15psi out of the pump. The guage is just before the carb and is new. The pump is mounted down near the tank. So am I sending it too much juice somehow? The hot wite to the pump is running strait into the fuse box to a keyed on source. Should I have an inline fuse on this wire? I'm confused because these pumps are supposed to put out a max of 6psi so I am not sure why I am getting the 15psi reading. Thats in advance for the help fellas. I don't want to screw up my new pump.
Re: Carter p4070 elec fuel pump question?
February 20, 2014, 09:21:12 pm »
It should require 12 volts, but I don't use electric pumps on carbs, the factory mechanical works fine and lasts forever for me.
I would check to see if you have a restriction in the line.
ian75c10
February 20, 2014, 09:24:13 pm »
Thanks Capt, could you explain a restriction? I am a bit confused because I am worried I have too many volts going to the pump making it run in mega high gear to give me too much gas at 15 psi. Sorry I am learning all of this. Thanks
February 20, 2014, 09:38:26 pm »
I am not familiar with that pump at all, but if it is for automotive use it should take 12 volts. It should come with a suggested wiring also.
As for restriction, remove the hose from the end and see if it free flowing.
HAULIN IT
February 22, 2014, 03:05:41 pm »
Ian, Does your pump have 1/4" fittings or 3/8" fittings?
ian75c10
February 23, 2014, 08:36:39 pm »
It has 3/8 fittings, I have it all together now. Seems to be running really good. The one thing thats off id I have the regulator set at 3.5 psi and the gauge is reading 5.
HAULIN IT
March 09, 2014, 05:44:43 pm »
Quote from: ian75c10 on February 23, 2014, 08:36:39 pm
It has 3/8 fittings
Exactly! I'm guessing you don't have the 4070..which has 1/4" fittings, but the 4601 which has 3/8" fittings & a max pressure of 16, which the couple I've used showed about 14-15psi. Maybe boxed wrong? Lorne
Performance
