Author Topic: Whats a good spray-on frame protector?  (Read 9143 times)
Offline cwest
« on: March 07, 2014, 08:34:29 am »
My frame is in pretty good shape, but there is some spots where the original coating is wearing off and surface rust is making an appearance.  Anyone have a suggestion for simple spray-can type frame coating/protector?
86' Chevy K20
350/SM465/np208
08' Silverado 1500 4X4 WT
Offline LTZ C20
Re: Whats a good spray-on frame protector?
« Reply #1 on: March 07, 2014, 08:57:49 am »
Duplicolor makes a rattle can called "Bed Armor" or "Truck Bed Coating". It's the same stuff just 2 different names. If you find a can with "truck bed coating" it's just the older style label. Stuff works pretty freakin good. Used it to coat my front frame when I put a new engine in. Looks killer. You can get it at any auto parts store. Probably Lowes and Home Depot or Orcharch Supply too.
LTZ Cheyenne C20
« Reply #2 on: March 08, 2014, 01:57:36 pm »
I would use Chassis Saver or POR15.
Offline winky
« Reply #3 on: March 08, 2014, 02:35:17 pm »
x2 on what Captkaos said. I always thought that stuff was over rated until we used some in the shop one day... if its worth doing, its worth doing right :D
« Reply #4 on: March 08, 2014, 03:22:21 pm »
Is the frame undercoated?
Offline cwest
« Reply #5 on: March 08, 2014, 07:27:05 pm »
I believe the frame was originally undercoated as well as the previous owner would coat it with his used oil.  It's in great shape, just has a couple spots that are starting to show some surface rust.  I want to catch it before it turns into more than that
86' Chevy K20
350/SM465/np208
Offline flips87c30
« Reply #6 on: March 09, 2014, 09:09:04 am »
x3 I used por 15 on my plow and I'm incredibly happy with it.
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
« Reply #7 on: March 09, 2014, 10:44:34 am »
Don't use anything other than undercoating or body shutz at this point unless you intend to strip the frame.
« Reply #8 on: March 09, 2014, 11:43:38 am »
     As Vile said, unless you are going to prep an area right, spraying something over the "spots" will only give you or someone else surprises down the road.
Offline cwest
« Reply #9 on: March 09, 2014, 01:59:54 pm »
Little surface spots like that are what I'm talking about.  Would a good session with a wire brush drill bit attachment be prep enough, or would a little angle grinder session be more appropriate?
86' Chevy K20
350/SM465/np208
« Reply #10 on: March 09, 2014, 02:42:01 pm »
Use a needle scaler some safety glasses and ear protection. Knock the loose stuff off and use body shutz or undercoating. Don't invest in a frame paint unless you're going to do it right which means stripping it down bare.
Offline blazing816
« Reply #11 on: March 10, 2014, 10:24:17 am »
x2
Offline ehjorten
« Reply #12 on: March 12, 2014, 01:52:32 pm »
NOX-Rust X-121 or X128!
-Erik-
