Author Topic: 91 burb wiring harness in 82 c10  (Read 4087 times)
Offline bh867
« on: March 07, 2014, 09:16:43 pm »
Hey guys I have an 82 c10 and I wanted to swap the steering column and wiring from my 91 parts burb. Where I got confused was with the electronic speedo. I run a th350 but I'm not opposed to swapping trannys in fact I'd prefer it I just don't know if I want to right now. I planned to use all of the wiring and just remove the extra suburban stuff that I wouldn't need such as rear heat etc. My question is this, besides the speedo what else is different from say an 87? And what options do I have for a speedo besides swapping trannys? I'm taking the windshield wiper motor, heat/ac control and whatever else I need to. I'm very familiar with 81-87 but haven't played with anything after that. I'm swapping a tbi motor into the 82 and running a carb setup so I don't need the efi stuff but I want to keep the cruise and it'd be easiest to match up the column and everything else if possible. Any insight with this or anything else that I might not be realizing would be greatly appreciated
Sent from my iPad using Tapatalk HD
Using Tapatalk
Re: 91 burb wiring harness in 82 c10
« Reply #1 on: March 08, 2014, 01:48:42 pm »
You could swap the cluster with it or just use what is in the TH350.  The Signal from the 1991 is only used for the ECM and speedo.
Offline blazing816
« Reply #2 on: March 10, 2014, 09:05:55 am »
Like Capt said you can still just run your manual speedo cable as long as you keep the manual speedo.
