73-87 Chevy & GMC Trucks
Need immediate help
Topic: Need immediate help (Read 4265 times)
DanBej
Need immediate help
March 08, 2014, 12:08:25 pm »
I've recently taken apart my steering column to replace my turn signal switch. Now that I'm putting it back together I'm having this problem. I can't push it back far enough for the bolt to catch. Please help I've been at it for days.[/img] picture below
Re: Need immediate help
March 08, 2014, 12:37:42 pm »
Huh?
DanBej
March 08, 2014, 12:41:46 pm »
DanBej
March 08, 2014, 01:33:40 pm »
I can't push the housing far back enough
March 08, 2014, 01:36:42 pm »
Is it still in the truck? The single is one of the first things to remove.. It looks like you pulled the internals out.
DanBej
March 08, 2014, 01:46:54 pm »
Yes its still in the truck. I need to push that metal housing? further back to tighten the 4 screws
March 08, 2014, 03:19:32 pm »
What exactly are you trying to do? You said you were replacing the turn signal switch but it looks like you went a lot deeper than that. If you really want help you're going to need to be a little more descriptive on what you are doing.
DanBej
March 08, 2014, 04:42:09 pm »
In order to pull the old switch out I had to go that deep. Seems like I fixed that problem but now that I put every thing back together including the new switch, the truck won't start and the key is stuck in the ignition
Need immediate help
