Author Topic: darn turn signals...  (Read 5653 times)
Offline rusty_but_trusty_86
  • mudder on high school budget
« on: March 13, 2014, 10:41:34 am »
well i now got 3 trucks. my 87 v10, my 86 k20 i picked up for $1050 last month, and the 87 r10 that i picked up a few weeks ago for $500. Well two nights ago i was drivin home from the ex gals house in the 87 r10 that im using as my daily and everything was working perfect and completely right.... well yesterday morning I get in the truck to head to school and the turn signals dont work whatsoever... doesnt matter which way I flick it.. everything else works except the turn signals (well i dont know about the hazards cuz i for got to check em, but putting the stick up or down does absolutely nothin... there is no turn lights goin on, clicking, blinking or anything happening when i move it.... needless to say im a little angry............ i already checked the fuse and it aint blown, and also put new flasher on, and also swapped between the 4 way flasher and all that and does absolutely nothing...... what could it be???????????
« Last Edit: March 13, 2014, 11:36:07 am by rusty_but_trusty_86 »
ashes to ashes...dust to dust... if it weren't for your ford...my tools would rust!
Offline pcguysam
  • Total N00B
Re: darn turn signals...
« Reply #1 on: March 13, 2014, 11:07:19 am »
The switching mechanism inside the steering column might be worn out.  You can remove the steering wheel and rent a removal tool from O'Reilly or Autozone to get the metal sproket underneath off and inspect it.
« Last Edit: March 13, 2014, 11:46:06 am by bd »
81 C10 Custom Deluxe Stepside Purchased 2/2013
« Reply #2 on: March 13, 2014, 11:41:56 am »
just lovely.... i was prayin i wouldnt have to tear apart my column... at least on the bright side i have an extra automatic non tilt column at the shop... do you have any pics of what this gear looks like?
« Reply #3 on: March 13, 2014, 12:20:59 pm »
How-To: Fixing a Sloppy GM Tilt Column is an illustrated tear down of the upper column.  Whether you have tilt or not, the process is the same down to replacing the turn switch.
Before you tear the column apart, check the operation of the 4-way flashers.  If the hazard flashers don't work either, make sure that the turn switch isn't just unplugged under the dash.
« Reply #4 on: March 13, 2014, 07:26:14 pm »
     That is the way to go, no need to do all that work if it is something simple.
« Reply #5 on: March 14, 2014, 11:38:10 am »
update.. after messing withe hazard switch yesterday pushing it in and pulling it out.. the turn signals started working, but hazards dont work
« Reply #6 on: March 14, 2014, 02:15:30 pm »
Replace the turn switch....
Or, you can try washing the contacts with some electronics tuner cleaner that contains lubricant.  Either way, tear down will be almost the same.  The outcome with tuner cleaner will be hit-and-miss.
