Author Topic: transfer case noise  (Read 4306 times)
Offline kodalee
transfer case noise
« on: March 19, 2014, 05:37:39 pm »
I have a 85 k10. I didnt hear anything until i put a lift on the truck. It is making a knocking only when i 4x4. you can only hear it when sitting in the cab. cant hear it from outside the truck. there is only maybe 1/2 inch between the front drive shaft and the transfer case skid plate. i can only hear it every once in awhile sometimes its wore then others.
Offline thirsty
    • Suitor's Garage
Re: transfer case noise
« Reply #1 on: March 19, 2014, 06:23:31 pm »
Check your front drive shaft for starters. Make sure all the u-joints are good and also the splines on the slip joint.
How much lift did you put on the truck? You may need a longer drive shaft. In either case you have changed the angle that the shaft is accustomed to and it may be showing it's age.
Offline kodalee
« Reply #2 on: March 19, 2014, 06:32:58 pm »
driveshaft was just rebuilt not a month ago. every piece is brand new. i installed a 4 inch lift with 33 inch tires
« Reply #3 on: March 20, 2014, 04:24:34 am »
my 84 does this, i havnt really looked at it but it almost sound like the t-case is hitting the floor. could be a bad motor or transmission mount
« Reply #4 on: March 21, 2014, 05:43:34 pm »
     I would look at both of these closely.  Also does it make the noise all the time in 4x4, or like when you are flexing the suspension ?  The more detail you can give us the better the answer's will be.
« Reply #5 on: March 21, 2014, 10:35:35 pm »
mine is when you hit a bump. in 4wd, dont think it does it when you get on it (didnt do it at the truck pull)
