Author Topic: Tachometer Grommet Firewall Picture  (Read 7819 times)
Offline acfixerco
« on: April 12, 2014, 12:28:52 pm »
Hi,
I have a 1982 silverado with factory gauges and the large gas gauge to the right of the speedometer.  Recently I scored a factory gauge cluster with tachometer and wiring harness from a 1981 at my local pick a part.
Being a bonehead, I did not take a picture of the firewall where I removed the grommet that transitions the firewall to the interior.
Would any of you please post a photo of the under hood grommet location on your firewall?
I know it is plug and play and it has been mechanically refurbished at a local speedo shop.
Thanks,
acfixerco
Offline KWKENUF
Re: Tachometer Grommet Firewall Picture
« Reply #1 on: April 12, 2014, 01:46:11 pm »
There is a big bundle of wires that pass through a grommet,  your tach wire should go through the same one.
Offline acfixerco
« Reply #2 on: April 12, 2014, 02:47:16 pm »
I appreciate your reply.
The factory harness has a white lead with an affixed grommet that transitions the firewall, connects to a condenser mounted to the exterior of the firewall then proceeds to the tach terminal of the distributor.
This is not one or more wires, it is a factory dedicated single wire attached to the grommet.  Know anyone with a 73-87 w/ factory tach?
Offline KWKENUF
« Reply #3 on: April 13, 2014, 12:23:50 pm »
Must be the tach signal filter you are talking about.  Sounds like you know know more than me,  so I can't be any help.  Sorry.
Offline Sartobuilt
« Reply #4 on: April 13, 2014, 06:32:06 pm »
This is on my 1980. Its the white wire @ 4 o'clock from the bulkhead connection. There are dimples in the firewall for locations. The tac wire is a single wire with a gromet molded on.
Offline acfixerco
« Reply #5 on: April 14, 2014, 04:36:09 pm »
Thank you so much!  I could not have received a more clean photo and instruction.  Appears you are doing a restoration, nice.
