Author Topic: My 78 k10 4x4 build thread -454 install / build -1 ton axles- frame restoration  (Read 581902 times)
Offline FearNoMan78k10
  • A project turned into a complete rebuild
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Before sanding for the final time.... This is after sanding multiple times... There was a THICK HARD LAYER of dirt encasing the entire under side of the bed.... Took forever to get to the actual paint and metal
Sent using Tapatalk
78 k10 4x4
And before I cleaned it before sanding.....
Sent using Tapatalk
78 k10 4x4
The weather has NOT been normal up here.... Lots of storms ... Rain... Lightening ... Thunder and wind......
Sent using Tapatalk
78 k10 4x4
I just put my nose to the grind stone and finally almost finished it! I had to build a fort over it to protect it from the rain and continue painting it! Lol !
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Here's the sand paper and the sander I used.... Sander is all I had to work with ...... Literally.......
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
My get it done motivation helper ....
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Loool..... Couldn't even hear the sander let alone anything else! Tunes help getting work done.... At least for me.... It helps
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
