Members Rides
My 78 k10 4x4 build thread -454 install / build -1 ton axles- frame restoration
37
38
39
40
92
Topic: My 78 k10 4x4 build thread -454 install / build -1 ton axles- frame restoration (Read 560838 times)
FearNoMan78k10
A project turned into a complete rebuild
Re: My 78 k10 4x4 build thread -454 install / build -1 ton axles- frame restoration
Reply #555 on:
September 01, 2014, 12:28:13 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #556 on:
September 01, 2014, 12:28:41 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #557 on:
September 01, 2014, 12:29:09 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #558 on:
September 01, 2014, 12:30:41 am »
Before sanding for the final time.... This is after sanding multiple times... There was a THICK HARD LAYER of dirt encasing the entire under side of the bed.... Took forever to get to the actual paint and metal
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #559 on:
September 01, 2014, 12:31:02 am »
And before I cleaned it before sanding.....
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #560 on:
September 01, 2014, 12:31:47 am »
The weather has NOT been normal up here.... Lots of storms ... Rain... Lightening ... Thunder and wind......
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #561 on:
September 01, 2014, 12:32:42 am »
I just put my nose to the grind stone and finally almost finished it! I had to build a fort over it to protect it from the rain and continue painting it! Lol !
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #562 on:
September 01, 2014, 12:33:08 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #563 on:
September 01, 2014, 12:33:39 am »
Here's the sand paper and the sander I used.... Sander is all I had to work with ...... Literally.......
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #564 on:
September 01, 2014, 12:34:01 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #565 on:
September 01, 2014, 12:34:23 am »
My get it done motivation helper ....
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #566 on:
September 01, 2014, 12:34:43 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #567 on:
September 01, 2014, 12:35:03 am »
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #568 on:
September 01, 2014, 12:36:11 am »
Loool..... Couldn't even hear the sander let alone anything else! Tunes help getting work done.... At least for me.... It helps
Sent using Tapatalk
78 k10 4x4
FearNoMan78k10
Reply #569 on:
September 01, 2014, 12:36:40 am »
Sent using Tapatalk
78 k10 4x4
37
38
39
40
92
Members Rides
