Projects Posts (NOT VEHICLES)
making an air cleaner with dual intakes..
Topic: making an air cleaner with dual intakes.. (Read 29520 times)
dvdswan
April 21, 2014, 08:14:37 pm »
So as the title says, I'm going to attempt to make a air cleaner with dual snorkels/openings/mouths/whatever you call them... I remember seeing one on a truck when I was a kid and thought it was cool. I also remember either Olds or Buick had them on some of the models.
So I went to the local pick-n-pull and found some donor air cleaner assemblies...
cut up the rusty one for the snorkel and placed it in some distilled vinegar to soak... after 24 hours and a brush with a toothbrush they look like this...
so now to trim it up so I can graft it into the other air cleaner assembly.
Dave
78 K10 Stepside
http://s36.photobucket.com/user/dvdswan/story/10553#
bake74
Re: making an air cleaner with dual intakes..
April 21, 2014, 08:29:05 pm »
Do not know if you saw these, they might help you out some.
http://www.73-87.com/7387garage/drivetrain/ram_air.htm
(has a link inside for ram air intakes)
Hauling it's dual snorkel on his truck.
I have always liked making some things myself and custom to my taste, so I will be following this thread to see what you do.
Last Edit: April 21, 2014, 08:32:10 pm by bake74
74 k10, 77k10 Tom
dvdswan
April 21, 2014, 08:34:59 pm »
that's exactly what I'm going for. that's awesome. if that's an actually Olds air cleaner assembly I bet he's pissed off some Olds guys. lol.
Dave
78 K10 Stepside
bake74
April 21, 2014, 08:38:37 pm »
I believe the story goes he used to have an Old's diesel in his truck before he switched it to gas.
74 k10, 77k10 Tom
dvdswan
April 22, 2014, 04:32:05 pm »
so I took out the piece, washed it off, dried it as quick as I could and primed it. it still did a little flash rust it a couple of areas. took a before picture of my original air cleaner lid before I put it in the tub of vinegar.
then started working on the air cleaner. cut out the opening for the 2nd snorkel..
fit the two together..
tacked and then welded...
cleaned it up and primered it...
and painted. very happy with the outcome. its actually a satin finish so it won't be this shiny.
Dave
78 K10 Stepside
bake74
April 22, 2014, 04:40:32 pm »
That turned out really nice, another thread to be saved for future reference. Thanks dvdswan.
74 k10, 77k10 Tom
FlatBlack77
Cheap Fast Reliable - Pick 2
April 22, 2014, 10:38:47 pm »
wow great work dude came out looking awesome.
if you dont know where to look it aint even noticable
LTZ C20
April 22, 2014, 11:22:44 pm »
That looks killer man! I was gonna build one of these too. Looks like I better get to work! I hope mine comes out as nice as yours.
Last Edit: April 22, 2014, 11:25:19 pm by LTZ C20
LTZ Cheyenne C20
dvdswan
April 23, 2014, 07:00:08 pm »
thanks guys. now I just have to find some factory intake tubing. I did find one but it was trashed on the air cleaner side.
Dave
78 K10 Stepside
LTZ C20
April 23, 2014, 08:04:58 pm »
Everytime I think about this I want to build it more and more. I should just go start on it because it's driving me crazy.
LTZ Cheyenne C20
HAULIN IT
April 23, 2014, 08:37:02 pm »
An easier way to do it is to either use a holesaw, drill Two holes & connect them where the second snorkle will go or a small wiz wheel & cut a rectangle. On the "scrap" air cleaner, use a wiz wheel on grinding wheel on the inside 4 corners & grind through the little spotwelds & remove the snorkle...this way the air cleaner base remains all one-piece, weld the snorkle back on from the inside & there is no finish work.
If a person doesn't have access to a welder, a 1/4" "flange" of the scrap air cleaner could be left on the snorkle & pop rivets used in the 4 corners to attach it to the air cleaner.
Mine is an Original Oldsmobile air cleaner, so I removed the original long tapered snorkle with the bell mouth on the end & installed both of the truck snorkles.
I also clocked the vacuum pull-off to route the hoes so they looked like a factory deal. Hope this Helps, Lorne
dvdswan
April 23, 2014, 10:18:55 pm »
that's a great idea Haulin it. I didn't think of that, it might have been a little easier too.
Dave
78 K10 Stepside
eventhorizon66
May 09, 2014, 05:56:48 am »
Impressive. You did it the professional way! I did the same thing Haulin just posted above using two tbi-era intakes.
'85 C10 SWB 350
700R4
TKO600
roundhouse
May 09, 2014, 02:06:14 pm »
The 66-68 Toronado had a very handsome dual snorkel air filter
rich weyand
May 20, 2014, 12:31:50 pm »
Hard to beat the '67 Olds 4-4-2 W-30 setup.
