Author Topic: 700R4 Dipstick For A 73 K5  (Read 5202 times)
Offline misweetrevenge
« on: May 02, 2014, 02:05:12 pm »
So the previous owner installed a 700R4 and put a chrome tranny dipstick in it. I don't trust the thing.
If I pull a dipstick out of a junkyard truck with a 700R4 will it read correctly?
I think the body measurements are fairly similar but I want to be positive it will read correctly.
1973 K5
Crate GM 350, Carter AFB Competition Series 625CFM 4bbl, SP2P Intake Manifold, Hedman Headers, 700R4, 3.55 Gears, 35x12.5x15 BFG KM2s
Offline dvdswan
Re: 700R4 Dipstick For A 73 K5
« Reply #1 on: May 02, 2014, 06:24:28 pm »
it should just drop right in, measurements should be correct.  be sure to get a new o-ring gasket.  one thing you may want to check to see if it has an aftermarket deep dish pan or stock pan.
Online bd
« Reply #2 on: May 02, 2014, 07:51:38 pm »
General information - A deeper pan won't make any difference to dipstick length since "Full" for a deep pan is the same fluid level, relative to filter position and the case, as "Full" for a stock pan; all 700R4 filters share the same dimension (drop) from the case.  Dipstick length is more closely related to dipstick tube length.
« Reply #3 on: May 02, 2014, 09:00:27 pm »
This is correct.
1973 K5
Offline dvdswan
« Reply #4 on: May 02, 2014, 10:15:10 pm »
I realize that, I was going of the fact that maybe the aftermarket pan may have came with a longer dipstick as well.  but after thinking about it, that would be pretty foolish to do that.
Online bd
« Reply #5 on: May 03, 2014, 12:06:07 am »
I realize that, I was going off the fact that maybe the aftermarket pan may have came with a longer dipstick as well.  but after thinking about it, that would be pretty foolish to do that.
I'm sure someone, somewhere has done it.  LOL
