Author Topic: Is this a temperature sensor on the drivers side head?  (Read 4220 times)
Offline G-NUT
« on: May 05, 2014, 05:02:41 pm »
While removing my spark plug wires I tried to pull off a single wire connector to get it out of the way.  When I did, the plastic connector crubled apart leaving behind a funny looking female type connector.  It almost looks like a female spade connector.  I'm trying to locate another to replace it with.  In doing so, I'm not sure what connector this is.  It resembles a temperature sending unit but it's located down on the drivers side of the motor; between the 1st and 2nd spark plugs.
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
Re: Is this a temperature sensor on the drivers side head?
« Reply #1 on: May 05, 2014, 05:53:15 pm »
Yes, That's your temp sending unit
Offline G-NUT
« Reply #2 on: May 05, 2014, 06:32:32 pm »
Cool.  Thanks.  Know where I might get a pigtail of one?  I looked at RockAuto.com, O'reilly's, and AutoZone so far.  Can't find one.
Offline jaredts
« Reply #3 on: May 05, 2014, 06:36:37 pm »
It's a regular female spade.  Get a good one.
« Reply #4 on: May 05, 2014, 06:37:34 pm »
A simple spade connector is all it really is.
Offline rich weyand
« Reply #5 on: May 05, 2014, 07:26:50 pm »
What year is your truck?  Earlier ones used a different connector that could be mistaken for a spade connector, but really slid on from the side.  Does your temp sender have a spade connector on the end, or does the connector on the end look more like a brass nail head?
« Reply #6 on: May 05, 2014, 09:29:11 pm »
I took a regular spade connector, removed the plastic sleeve and used shrink tube from the end of the connector back about an inch onto the wire. The wire is basically just a ground for the gauge and the sending unit is a variable resister controlled by heat. More heat = less resistance.
Offline CipherLogic
« Reply #7 on: May 06, 2014, 01:40:53 am »
You could probably use one with a plastic sleeve and just a notch in the side of the plastic to accept the connection.
