Author Topic: Plugs on passenger side much lighter  (Read 3561 times)
Offline ian75c10
    • Art Dir / Designer Ian Goolsby
« on: May 12, 2014, 09:52:29 am »
hey guys the other day I noticed what almost sounds like a lifter tick. Very slight. It increases and decreases tick revolutions with rpm speed. I first went to check my plugs thinking I might have one that was slightly fouled. No plugs were fouled but it was strange that all of the plugs on the passenger side were really white and all 4 on the drivers side were pretty black rich. Whats up with that? I do know I have a slight exhaust leak at the header flange on the passenger side but would that cause this side to run lean? I am wondering if I have a vacuum leak on that side somewhere? Maybe intake? I checked all bolts and seem to be tight. Just wanted to get some opinions from the pros on what to do next. Thanks guys
Offline CipherLogic
Re: Plugs on passenger side much lighter
« Reply #1 on: May 12, 2014, 11:16:01 am »
Single plane or dual plane intake?
Offline ian75c10
« Reply #2 on: May 12, 2014, 11:22:53 am »
Its a Wieman stealth and I believe it dual plane. But truly I am not sure. I just looked on summit and all the Stealth intakes for Chevy small blocks are dual.
Offline rich weyand
« Reply #3 on: May 12, 2014, 07:30:02 pm »
You could have an air leak on the passenger side, such as from a worn throttle plate hinge hole in the carb body, or a fuel leak on the driver side, such as a leaking casting plug in the base of the carb (assuming Qjet).  Sounds more like a fuel leak on the driver side to me.
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
« Reply #4 on: May 12, 2014, 09:13:11 pm »
Spray some WD-40 or starter fluid around the intake (slowly) and listen for an increase in RPM's That will tell you if there's a leak and where it is.
