Author Topic: 1979 c10 inline 6 w/power steering belt falling off  (Read 4585 times)
Offline Lowhoe775
« on: May 17, 2014, 08:19:56 am »
Have a problem with my v belts falling off. The water pump pulley is not lining up with crank . Water pump pulley is in about 1/2" difference than crank pulley. Replaced belts two times and they get put on tight. I think it can be the water pump pulley is going bad and for some reason is being pushed towards the engine more. Please help thank you
Offline Lowhoe775
Re: 1979 c10 inline 6 w/power steering belt falling off
« Reply #1 on: May 17, 2014, 08:21:08 am »
« Reply #2 on: May 17, 2014, 08:22:03 am »
Check to see that your crank harmonic balancer isn't loose
« Last Edit: May 17, 2014, 08:24:29 am by zieg85 »
Offline Lowhoe775
« Reply #3 on: May 17, 2014, 09:39:52 am »
I tried tugging back and forth on it and it's not moving will try and see if the bolt is tight today. Thank you
« Reply #4 on: May 17, 2014, 09:51:50 am »
Lay underneath the front and see if the balancer is walking off the crankshaft.  I think the I-6 are a press fit and I've had them come loose
Offline Lowhoe775
« Reply #5 on: May 17, 2014, 03:25:21 pm »
Took off the crank pulley and found that it was bad. Rubber showing in pic. Anyone having this problem you need to replace the crank pulley
« Last Edit: May 21, 2014, 08:41:56 pm by Lowhoe775 »
Offline Lowhoe775
« Reply #6 on: May 21, 2014, 08:43:22 pm »
Offline 1979ChevyMorgan
« Reply #7 on: June 06, 2014, 05:41:09 pm »
When you put those back on or want to tighten them make sure you use an installer, good chance youll strip the crank threads if you use the balancer bolt.
