1979 c10 inline 6 w/power steering belt falling off
Topic: 1979 c10 inline 6 w/power steering belt falling off (Read 4591 times)
Lowhoe775
May 17, 2014, 08:19:56 am »
Have a problem with my v belts falling off. The water pump pulley is not lining up with crank . Water pump pulley is in about 1/2" difference than crank pulley. Replaced belts two times and they get put on tight. I think it can be the water pump pulley is going bad and for some reason is being pushed towards the engine more. Please help thank you
Lowhoe775
Re: 1979 c10 inline 6 w/power steering belt falling off
May 17, 2014, 08:21:08 am »
zieg85
May 17, 2014, 08:22:03 am »
Check to see that your crank harmonic balancer isn't loose
Last Edit: May 17, 2014, 08:24:29 am by zieg85
Lowhoe775
May 17, 2014, 09:39:52 am »
Quote from: zieg85 on May 17, 2014, 08:22:03 am
I tried tugging back and forth on it and it's not moving will try and see if the bolt is tight today. Thank you
zieg85
May 17, 2014, 09:51:50 am »
Lay underneath the front and see if the balancer is walking off the crankshaft. I think the I-6 are a press fit and I've had them come loose
Lowhoe775
May 17, 2014, 03:25:21 pm »
Took off the crank pulley and found that it was bad. Rubber showing in pic. Anyone having this problem you need to replace the crank pulley
Last Edit: May 21, 2014, 08:41:56 pm by Lowhoe775
Lowhoe775
May 21, 2014, 08:43:22 pm »
1979ChevyMorgan
June 06, 2014, 05:41:09 pm »
When you put those back on or want to tighten them make sure you use an installer, good chance youll strip the crank threads if you use the balancer bolt.
