Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
A/C duc - Plastic pieces under dash. or that run to vents.
Topic: A/C duc - Plastic pieces under dash. or that run to vents. (Read 7645 times)
oldskool86
May 17, 2014, 10:47:58 pm »
installed all the A/C duc (plastic pieces under dash) today,
was wondering if there were brackets or what holds the middle vent and passenger vent to dash?
bd
Re: A/C duc - Plastic pieces under dash. or that run to vents.
May 18, 2014, 01:12:42 am »
Year and model of truck?
roundhouse
May 18, 2014, 05:56:37 am »
On my 82 they just slip into the dash pad. t He dash pad holds em
Sometimes it's hard to get em to stay in position till you gt the pad on. I've stuffed a little foam under em to hold them up and when you slide the pad in it pushes the foam out of the way
oldskool86
May 18, 2014, 09:17:36 am »
sorry. its a 86 chevy Silverado k10 4x4.
@ roundhouse. thanks i'll see if when I install the dash back in if they hold in place
Last Edit: May 18, 2014, 09:19:31 am by oldskool86
bd
May 18, 2014, 10:43:00 am »
The 86 has plastic studs protruding from the backside of the dash pad and steel nuts that retain the outlets directly to the pad. Not the best illustration, but see the
1986 Service Manual
, page 1B-36 (pg 99).
DnStClr
June 10, 2014, 10:17:58 pm »
I took a few pics that might help you see what Bd describes. Hope it helps..
Here's the dash panel insert with the plastic vent pieces- the dashpad goes between them.
This is what the vent pieces look like behind the dashpad.
This is a view of the plastic studs and nuts
Last Edit: June 10, 2014, 10:53:55 pm by bd
Don
87 Chevy Silverado
bd
June 10, 2014, 10:28:39 pm »
"A picture is worth a thousand words." Thanks, Don.
DnStClr
June 10, 2014, 10:37:34 pm »
They're kinda small views- I'd better learn to resize before I post pics...
Don
87 Chevy Silverado
bd
June 10, 2014, 10:55:53 pm »
Better?
DnStClr
June 11, 2014, 11:22:42 am »
"L I B "- Oldskool, I hope we've been of some help.
Don
87 Chevy Silverado
