Author Topic: A/C duc - Plastic pieces under dash. or that run to vents.  (Read 7650 times)
Offline oldskool86
installed all the A/C duc (plastic pieces under dash) today, was wondering if there were brackets or what holds the middle vent and passenger vent to dash?
Offline bd
Re: A/C duc - Plastic pieces under dash. or that run to vents.
« Reply #1 on: May 18, 2014, 01:12:42 am »
Year and model of truck?
Offline roundhouse
« Reply #2 on: May 18, 2014, 05:56:37 am »
On my 82 they just slip into the dash pad.   t He dash pad holds em
Sometimes it's hard to get em to stay in position till you gt the pad on.  I've stuffed a little foam under em to hold them up  and when you slide the pad in it pushes the foam out of the way
Offline oldskool86
« Reply #3 on: May 18, 2014, 09:17:36 am »
sorry. its a 86 chevy Silverado k10 4x4.
@ roundhouse. thanks i'll see if when I install the dash back in if they hold in place
« Last Edit: May 18, 2014, 09:19:31 am by oldskool86 »
Offline bd
« Reply #4 on: May 18, 2014, 10:43:00 am »
The 86 has plastic studs protruding from the backside of the dash pad and steel nuts that retain the outlets directly to the pad.  Not the best illustration, but see the 1986 Service Manual, page 1B-36 (pg 99).
Offline DnStClr
« Reply #5 on: June 10, 2014, 10:17:58 pm »
I took a few pics that might help you see what Bd describes. Hope it helps..
Here's the dash panel insert with the plastic vent pieces- the dashpad goes between them.
This is what the vent pieces look like behind the dashpad.
This is a view of the plastic studs and nuts
« Last Edit: June 10, 2014, 10:53:55 pm by bd »
Don
87 Chevy Silverado
Offline bd
« Reply #6 on: June 10, 2014, 10:28:39 pm »
"A picture is worth a thousand words."  Thanks, Don.
Offline DnStClr
« Reply #7 on: June 10, 2014, 10:37:34 pm »
They're kinda small views- I'd better learn to resize before I post pics...
Don
87 Chevy Silverado
Offline bd
« Reply #8 on: June 10, 2014, 10:55:53 pm »
Better?   :)
Offline DnStClr
« Reply #9 on: June 11, 2014, 11:22:42 am »
"L I B "- Oldskool, I hope we've been of some help.
Don
87 Chevy Silverado
