Author Topic: 84 Silverado K10 A/C Evaporator Core Replacement  (Read 7945 times)
Offline jpatters13
    • 74' Chevy Truck Project
« on: May 24, 2014, 11:08:59 am »
I am nearly certain the evaporator core is the originally installed one and is leaking, causing the a/c to not be able to hold a charge. Any special instructions I should know about before trying to replace it?  I believe I can remove half of the housing under the hood and get to it for removal, correct?  Is there anything I should know to save me a few four-letter words and a lot of time?  Please advise...
Thanks!
84 Silverado K10
74 Custom Deluxe C10
Offline jpatters13
84 Silverado K10
Re: 84 Silverado K10 A/C Evaporator Core Replacement
« Reply #2 on: May 24, 2014, 11:32:16 am »
Why do you think it's the evaporator? Sounds like you are not 100% certain. Did you leak test the system? Did you use UV Dye or you can use the poor mans leak detector (soap)
Here's another method
http://automotivetestsolutions.com/bullseye.html
Offline jpatters13
« Reply #3 on: May 24, 2014, 11:59:12 am »
We put a bright yellow dye in and never saw anything come out. A few weeks later the system was empty again. Occasionally there would be a small puddle of clear/bright yellowish oily stuff on the ground right behind the front passenger tire after being parked. It was rolling down from on top of the wheel well cover.
84 Silverado K10
Offline jpatters13
« Reply #4 on: May 24, 2014, 12:43:36 pm »
So I just began to take the system apart and found the system still has a charge.  I guess it might not be the evaporator core after all?  Anyone know how to test a compressor?
84 Silverado K10
« Reply #5 on: May 26, 2014, 08:33:43 am »
Pick up a UV light even a cheap UV pen light is only a few bucks at the parts store. Use a pair of yellow glasses and park it in the garage. Go over the entire system and carefully inspect. Most common leak points: compressor shaft seal, connections, condenser, valve core. You can also use a mechanic's stethoscope to try and listen for leaks but you'll need a very quiet area for this to work well.
