Author Topic: 83 K10 Project.  (Read 6175 times)
Offline dads83k10
83 K10 Project.
« on: May 27, 2014, 08:37:06 pm »
Hey everyone. I have spent the last 3 months searching different pages compiling information and parts list for the swap that will start this weekend.
 I have acquired my dad's old 83 k10, and I am about to try and bring it back to life. The goal is to replace the blown up 305 with a 5.3 Vortec. I also want to upgrade from the turbo 350 to a 4l60e to improve drivability. I will be posting pictures of the progress and most likely asking for advise from time to time.
Offline dvdswan
Re: 83 K10 Project.
« Reply #1 on: May 27, 2014, 10:08:40 pm »
I bet that's going to clean up nice.
Offline blazing816
Re: 83 K10 Project.
« Reply #2 on: May 28, 2014, 10:47:51 am »
welcome, looks like its going to be a good project
Re: 83 K10 Project.
« Reply #3 on: May 28, 2014, 07:56:51 pm »
     Welcome to the site, we will help you out when needed.
Offline dads83k10
Re: 83 K10 Project.
« Reply #4 on: August 25, 2014, 08:55:32 pm »
 I've ran into a slight snag, trying to set the motor in tonight but the left front of the oil pan is hitting the cross-member. I'm assuming that the motor mounts I have are incorrect.(hok-12621) I don't have a problem buying a different set,but if all of the mounts hit that location I don't see the need.Any help would be greatly appreciated.
Re: 83 K10 Project.
« Reply #5 on: August 27, 2014, 10:43:59 pm »
The member that did their 4x4 truck used Street and Performance mounts.  That is what I am using also.
The ones you listed move the engine forward 1.25" and up 1/2" which is probably causing your issue.  The S&P ones (plus many other plate versions) put the LS in the same location as the SBC that was removed.
