Author Topic: 75 K10 Engine ran in other truck,gets caught up turning in this one. HELP PLEASE  (Read 7648 times)
Offline Hillbillydrums
Hey guys. I'm getting pretty aggravated at this point, so lets just jump into it.  sbc 350, th350
About a year ago I bought my 75 k10. When being turned over, it would get a little stuck in places, and then free up, then again. My dad and I assumed something in the engine was stuck.
Recently, I bought a 76, for the engine that I know runs, and for some other parts.
Just put the engine in this week, and now it does the same thing! It does do full revolutions, it doesn't just hit a wall.
I even ended up unbolting the torque converter and it still does the same thing.
I have another tranny that i think is good. Do i have to swap them? If so, how do i?
Thanks in advance.
http://youtu.be/wxWudF-dmQ8
http://youtu.be/qqIu3ddgyk8
Videos of it trying to turn.
1972 C10 (Passed down since great granddad bought it new in '72)
1973 K5
1975 K10
Offline Turbostang7
Looks like the starter is weak or the battery needs charged, if you unhooked the torque converter and it still does it then it's not in he tranny.
A low CCA battery/weak and/or corroded (inside the insulation) would also cause this assuming your timing is set correctly.
Offline fitz
These guys are pointing you in the right direction.
With a fully charged battery try using some jumper cables to go from (+) to you starter and (-) to you engine block. This should let you know if your cables are bad. Like Zieg pointed out, they corode from the inside.
     X2 on what everyone said.
Offline thefarmboy21
Is it doing this by hand or from the key? If from key, it could also be a bad switch OR knocked out of time. If it's binding up by hand then you're doing something wrong.
AMSOIL DEALER # 5583011
86 Chevy K20 Custom Deluxe-Grandpa bought it new 11/20/85
77 Chevy K10 Custom Deluxe-Dad's first truck
69 Chevy C30 flatbed-Grandpa's farm truck
1950 International L-112-Grandpa bought it new, parked in 1963
Exactly what I thought. I have 3 different starters, one almost new. Tried them all. Charged the battery to make sure. Even left it on the charger and tried it's few times.
The distributer isn't in. I just put the engine and wanted to turn it over. But it gets caught.
I'll try this when I'm home.
it does if from the key, and then I made a starter switch going from the terminal of the starter to the battery to be able to troubleshoot while alone.
1973 K5
1975 K10
     At this point I would try 2 different things, like Zeig said, try to isolate the battery cables themselves to make sure they are good or bad.  Then turn it over by hand to make sure it is not something internal with your engine.
     Keep us posted.
     Keep us posted.
I had the engine in other truck a few weeks ago. Started right up. Ran great.
And the prior engine that was in it did the same thing. I figured bad engine, so I got this one.
1973 K5
1975 K10
OK you said you had the engine in the other truck, ran great.  When you put it in this one did you use the same cables from the other truck?
You do not have the ground cable connected to the engine.
X2 on this.  What gauge are the battery cables and where are they connected?  Do you have a voltmeter?
Holy shoot.
It was that simple.
1973 K5
1975 K10
Offline rich weyand
Yup.  Couple 2-3 times a month, it's bad starter cables or improperly connected grounds.
