Author Topic: How to remove AC control cluster from the dash 1974 C10  (Read 11283 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: June 22, 2014, 04:58:50 pm »
Anybody removed an A/C control cluster from a 1974 stepside C10?  It appears that my A/C compressor switch is not making contact as I get no 12 volts to the compressor when the A/C is on.  Looking to learn from somebody elses experience before I end up with the truck engine removed or down to the frame to get the switch out because I did not twist the cluster just so or some such.  Any help would be appreciated.  Thanks much.
Ricky
Offline roundhouse
Re: How to remove AC control cluster from the dash 1974 C10
« Reply #1 on: June 22, 2014, 05:41:29 pm »
Comes out pretty easy
Think you gotta pull the plastic bezel  first.   Them 4!screws holding control in
Offline roundhouse
« Reply #2 on: June 22, 2014, 05:42:12 pm »
Check and make sure you are getting power TO the switch  before you pull it out
Offline fiddler
« Reply #3 on: June 22, 2014, 08:50:44 pm »
Thanks for the inputs.  I have the bezel off.  I have the screws off.  I have dropped the radio down for clearance.  I have turned the AC cluster every which way but loose but I still cant get it out.  I was hoping to get it out in the cab so I could measure voltages and continuity and such.  The good news is that I ran the truck with air set to full on and then spliced 12 VDC into the AC clutch wire and the system pulls down and blows cold!  I am pretty sure the switch is the culprit.  So I will keep trying.  Maybe I can pull the harnesses while the switch is still under the dash and that would give me the clearance I need.
Ricky
Offline roundhouse
« Reply #4 on: June 22, 2014, 09:05:37 pm »
Check for some
Clips or anchors on the cable
That runs to the flaps under the glove box
You may have to unhook that cable to be able to twist the control
Enough to get it out
Offline fiddler
« Reply #5 on: June 23, 2014, 12:42:29 am »
Thanks much.  I'll try that tomorrow.
Ricky
Offline fiddler
« Reply #6 on: June 23, 2014, 08:42:04 pm »
OK roundhouse, that isn't helping.  Maybe I misunderstood about the plastic bezel.  You were talking about the main one that covers the speedometer and gauges right?  Or maybe I need to take the plastic bezel off of the switch cluster to find 4 screws underneath it and pull the front off of the switch cluster??  If this wasn't a hobby I would be plenty frustrated right now.  As it is...just amused at how they did this!!
Thanks in advance for any more advice you have.
Ricky
Offline fiddler
« Reply #7 on: June 24, 2014, 12:23:47 pm »
OK so I have the main bezel off and the screws removed from the AC control cluster and it it free to move about but I can't seem to twist it just so to get it out of the dash.  I can get the top right and bottom center screw tabs out but I can't get a 3rd tab out no matter how turn the thing.  I need to test the AC switch as my AC clutch does not energize.  I bypassed the switch and got the air to blow cold but I need to verify switch before ordering a new control cluster.
Ricky
« Reply #8 on: June 24, 2014, 06:31:16 pm »
     Did you check with the manual in the tech section found HERE.
Offline fiddler
« Reply #9 on: June 24, 2014, 09:43:29 pm »
Thanks!  It was in the manual.  On the 74 it needs to be disassembled and drop out the bottom.  I remember I was going to look there but had problems with logging in, and by the time I reset password and all I forgot who I was....let alone what I was doing.  I now have the manual on my computer.  978 pages of gold!
Ricky
« Reply #10 on: June 25, 2014, 07:54:42 pm »
Why are you taking it out? Sounds like you are backward troubleshooting your problem.
Offline fiddler
« Reply #11 on: June 26, 2014, 09:46:41 am »
So no power to the compressor clutch.  I was trying to get the harnesses out to where I can ohm paths.  I got it out and finally found (here) the right wiring diagram.  Turns out somewhere along the line the wiring was moved around a bit.  Some disconnected, some reconnected in wrong spots.  Anyway, straightened out wiring and added a line to after market fan controller so radiator fan comes on whenever air conditioning is on, only to discover that the air conditioner is always on.  (Looks to be by design).  Need to move my wire to where the radiator fan comes on when the clutch is energized.  That way I won't be running the fan all of the time.
Thanks for the reply!
Ricky
Offline fiddler
« Reply #12 on: June 30, 2014, 03:08:22 pm »
Thanks everybody!  So I got the air working perfectly as it was originally designed to work.  With the new interior that was installed before I bought the truck it is starting to look pretty good in there.  Coming along a bit at a time.  Next step is to repair the turn signal indicator so it cancels and to get the horn button wired up.  Right now the horn is on a toggle switch at the bottom of the dash board.  Just trying to get back to stock everything.  (May take some doing for the tail lights as they are from an International Harvester Pickup truck).
 Thanks again...
Ricky
« Reply #13 on: July 02, 2014, 09:02:41 pm »
So what was your problem with the AC?
