Author Topic: Heavy Half Ton Exhaust Question  (Read 7330 times)
Offline mizozuman2
  • Something goes here... but what?
« on: June 28, 2014, 08:17:40 pm »
I'm putting a new exhaust system onto my truck. It's an '86 C10 Heavy Half Ton truck, so it doesn't have Catalytic Converters stock. When putting this new exhaust on there, do I have to run Catalytic Converters since it's "aftermarket"?
Thanks!
1986 Chevrolet C10 "Heavy Half"
350 4bbl
Long bed/Reg Cab
Re: Heavy Half Ton Exhaust Question
« Reply #1 on: June 28, 2014, 08:24:12 pm »
I never seen a 86 C10 heavy half so verify by VIN to make sure.  Depending on how your state is you may have an issue.  Does your gas gauge say Unleaded Fuel Only?  It is a Federal Law that if your truck came with a converter it is supposed to have one on.  Some states are strict while others could care a less.  My $.02...
Offline DanMcG
« Reply #2 on: June 28, 2014, 08:33:59 pm »
Newbie here, what would tell you it's a heavy half in the vin, forth digit = E?
« Reply #3 on: June 28, 2014, 09:17:13 pm »
4 th digit is braking and 8 th digit is engine.  Then where it was manufactured for told you what driveability and emission controls it was originally came with.  Manual trans differed from automatics, high altitude, low altitude or both, then CA had special one
Looking in my book, C10's had 305's as the largest gas engine and all 305's had catalytic converters.  The heaviest GVW 3/4T with the larger engines 350/454 didn't have catalytic converters in stick shift I know for certain.
« Reply #4 on: June 29, 2014, 12:25:07 am »
the GVWR for heavy halfs had to be 6,050 and above, and afik it was only 75-80 when the government started putting emissions on vehicles gm made the heavy halfs to bypass these laws. then the government changed the laws to require all trucks under 8,500GVWR to have cats.
Offline mizozuman2
« Reply #5 on: June 29, 2014, 02:08:58 am »
I'm at 6,050 for my GVWR, or so it says on the sticker in my glove box. when I looked under the truck, I saw no cats.
350 4bbl
Long bed/Reg Cab
« Reply #6 on: June 29, 2014, 03:34:58 am »
"Light Duty trucks are 6001-8500 GVWR" are the same thing as 0-8500 and require emission testing after 1979 this is the clean air act of 1977
and heres something else
http://www.73-87.com/7387info/7387emislevel.htm
Offline mizozuman2
« Reply #7 on: June 29, 2014, 04:09:10 am »
I guess that makes me a polluter for right now... Good thing I don't have emissions in Kansas, and it's already registered in the state.
350 4bbl
Long bed/Reg Cab
« Reply #8 on: June 29, 2014, 04:16:59 am »
lol dont worry there are a lot of us just like you.
also fyi before these emissions problems the ford ½ton was called the f100 they did their own "heavy half" which is known as the f150 and they just kept the name
Offline DanMcG
« Reply #9 on: June 29, 2014, 04:54:03 am »
In NY you are exempt from the emissions inspection program if your vehicle is 26 model years old or older.
« Reply #10 on: June 29, 2014, 04:57:52 am »
in maryland you dont no inspection if your vehicle is over 20. in Delaware you have emissions only at idle if its 20 or 25 cant remember but you have driving restrictions with these tags ie only on weekends or to shows not DD, but for the most part if you dont make yourself to look like a butt they will leave you alone
Offline Stewart G Griffin
« Reply #11 on: June 30, 2014, 09:48:58 am »
@IA,
i thought "historic" meant you can drive it regular.  "Street rod" was only on weekends/shows etc.?
« Reply #12 on: June 30, 2014, 09:49:51 am »
Oh, P.S.,
In my opinion, if the truck never came with cats, then you don't need to add them.  Aftermarket or stock exhaust doesn't matter.
« Reply #13 on: June 30, 2014, 07:02:03 pm »
if the truck never came with them then no, but the when a truck is 30+ years old most on here weren't even born when it came out ;) you also cant go by a sticker in the glove box cause they can me switched out
Historic
"A vehicle registered as historic cannot be used for general daily transportation, or primarily for the transportation of passengers or property on highways.  It can only be used in exhibitions, club activities, parades, tours, occasional transportation and similar uses.  A trailer does not qualify for historic registration."
http://www.mva.maryland.gov/about-mva/info/27300/27300-28T.htm#historic
Street rod
"A vehicle registered as a street rod cannot be used for general daily transportation, or primarily for the transportation of passengers or property on highways.  It can only be used in exhibitions, club activities, parades, tours, occasional transportation and similar uses."
http://www.mva.maryland.gov/about-mva/info/27300/27300-28T.htm#street_rod
Delaware antique
"c) Any antique motor vehicle, registered pursuant to this section, shall be used only for participation in club activities, exhibits, tours, parades and similar uses, but in no event shall it be used for general transportation."
http://www.dmv.de.gov/services/vehicle_services/titles/ve_title_antique.shtml"
