Engine/Drivetrain
Leaking np 205 from top
Topic: Leaking np 205 from top (Read 3035 times)
Sprinkler-Man
80 GMC Sierra Classic 4x4
June 29, 2014, 03:50:58 pm »
My np 205 appears to be leaking somewhere at the top of the case. I took off the boot on the shifter and the solenoid where the 4wd indicator connects to is all wet. Could this be the problem?
Sprinkler-Man
Re: Leaking np 205 from top
July 28, 2014, 09:42:54 pm »
I confirmed that the overflow tube is not leaking and it looks the problems are coming from the shift input shafts. Do I need to pull the case and replace the seals from the inside?
Engineer
July 29, 2014, 03:38:34 pm »
No. The shift linkage seals can be replaced simply by digging out the old ones, and pressing in the new ones.
Removing/disassembling the case won't help you at all.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Sprinkler-Man
August 11, 2014, 09:22:25 pm »
Thanks, I will look at the NP 205 manual and see how to do it.
Engine/Drivetrain
