Author Topic: vacuum lines  (Read 4871 times)
Offline rwalk911
vacuum lines
« on: July 04, 2014, 12:11:38 pm »
I have a 1981 Chevy c10 that was originally a diesel, but has a Chevy 350 in it now. It has a 1406 Edelbrock carburetor on it, but I am not sure what vacuum lines go where. I also don't know if a line should run from the brake booster to the carb or intake. Also, where does the transmission vacuum line attach?
Offline winky
Re: vacuum lines
« Reply #1 on: July 04, 2014, 12:42:07 pm »
my trans vacuum line on my 77 was on the intake and so was my brake booster. i don't think the location matters too much but i may be wrong.
Offline winky
Re: vacuum lines
« Reply #3 on: July 04, 2014, 01:01:41 pm »
this is a  vacuum diagram for an 81 305 federal, Auto trans, And California smog. it should be the same concept for what you need though. i would run the manifold vacuum to my brake booster, then run vacuum off the carb to the trans, and pcv valve, and the distributor. some intakes came with a fancy "tree" that plugged into the intake and had 6 vacuum ports. im sure someone else will chime in.
EDIT:
BD beat me to it.. lol
Offline rwalk911
Re: vacuum lines
« Reply #4 on: July 05, 2014, 09:35:37 am »
Thanks for the help, but I can't figure out where the line goes on the brake booster side. Does anyone have an actual pic?
Re: vacuum lines
« Reply #5 on: July 05, 2014, 10:23:45 am »
The brake booster hose connects to the 3/8" nipple on the manifold vacuum tee.  The manifold vacuum tee typically threads into a 3/8" NPT port near the intersection of the #8 and #5 runners, directly behind the carburetor (see image, below).
Re: vacuum lines
« Reply #6 on: July 05, 2014, 10:33:07 am »
The 11/32" vacuum hose connects to the booster through a plastic check valve.
« Last Edit: July 05, 2014, 10:39:08 am by bd »
