Leaf spring broke off
Topic: Leaf spring broke off (Read 11367 times)
jumpkickyergunt
July 18, 2014, 01:48:49 pm »
I'm driving down the road and I hear this massive banging noise. Check it out and the top piece cracked and broke right off. So upset as it could have really ruined someone's morning. I've never done this replacement before. Can I do it? The bolts seem pretty straight forward but I'm not sure where to start and how much leaf springs even cost. Very unhappy right now. Never seen this before.
jumpkickyergunt
Re: Leaf spring broke off
July 18, 2014, 01:55:15 pm »
79 k10 btw
Dan75k20
July 18, 2014, 03:44:48 pm »
Its not a hard job find a local spring shop or lift your truck !
timthescarrd
July 18, 2014, 04:14:43 pm »
Sounds like the Perfect excuse for a lift kit
Dan75k20
July 18, 2014, 06:10:43 pm »
Yep and will cost almost the same as stock springs
jumpkickyergunt
July 19, 2014, 01:03:17 am »
You guy are right. What are your recommendations on brands? I was wanting to do 4" and try to get some 33's in there. Any k10 experts know if that's enough lift?
July 19, 2014, 02:31:03 am »
some say you can fit 33's on a stock setup. it just depends on the springs and wear on them. so 4" you would fit 33s with no problem
Engineer
July 19, 2014, 08:38:20 am »
I like a 6" lift for 33"s, but that is just me. Cost is about the same as a 4", too.
Now repeat after me: Skyjacker. Skyjacker. Skyjacker.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
bake74
July 19, 2014, 10:14:37 am »
If you do go with just replacement springs instead of a lift, make sure you do at least both, do not do just the one that broke. Your truck will lean if you do only 1 spring instead of at least 2, better would be all 4.
74 k10, 77k10 Tom
jumpkickyergunt
July 19, 2014, 05:14:45 pm »
Sky........jackaaaaaaaa
I'm going to save up and do the lift. Skyjacker seems like the classy stuff. I like classy. De classay. That's french for classy.
jumpkickyergunt
July 20, 2014, 05:24:01 pm »
Ok guys, so I'm having a little trouble figuring out which particular kit I need. I want to do the 6" lift and skyjackers website has several options ranging from $725-$1400. If someone wouldn't mind filling me on the details of why one is worth it over the others (or for fitment purposes) then please let me know. It is much appreciated.
July 20, 2014, 06:55:12 pm »
What size tires are you running? With a 6" lift you will need to make sure you modify the steering, check your pinion angle, driveshaft length, stabilizers, sway bar kit, drag link or crossover, brake hoses, shocks, Front hangers, steering arm and align. When you are purchasing a "kit" they usually do not include everything you need.
jumpkickyergunt
Reply #12 on:
July 20, 2014, 07:29:05 pm »
I was planning on doing 33's or 35's. That sounds like a lot of stuff and a ton of money I don't have. Well shoot. Can I get away with a 4" lift on 33's and do a lot less modification? I doubt this will be easy for me as I don't have all the necessary knowledge to make the correct decision.
roundhouse
Reply #13 on:
July 20, 2014, 08:54:01 pm »
33s will fit with no lift on most trucks
They should easily fit with a 2" lift. And with a 2" you shouldn't have any driveshaft. Or steering mods
Probably need a longer rear brake hose And you will need longer jocks
But you should change all the flex hoses anyway. My K-10 just popped a flex hose and lost all braking
You should be able to
Find a stock spring for free from
Someone putting in a lift
bake74
Reply #14 on:
July 20, 2014, 09:17:08 pm »
There is 1 important question/fact that has not been asked or answered yet.
What do you plan on using your truck for ?
Skyjacker is an excellent lift, nice ride and quality for the street. Hard core 4 wheeling not so much, it is a soft lift and therefor will lean and sway too much.
So you see, you really need to do some thinking and homework before jumping in.
If you are looking for 33" tires on a budget, roundhouse is right. Do a 2" lift, 33" will fit and never hit unless you do some extreme flexing or have the wrong backspacing on the rims, and will be the least amount of money for a lift.
See, needs homework first, I bet you never thought about backspacing for rims and how that affects the tires hitting the wheel wells when flexing.
74 k10, 77k10 Tom
