Author Topic: body change  (Read 13160 times)
Re: body change
« Reply #15 on: July 30, 2014, 12:20:57 pm »
If your gona lift the body do it right, get a kit.
Offline sameold
Re: body change
« Reply #16 on: August 02, 2014, 07:24:01 am »
Guys I appreciate all your help. I had to remove the entire heater core case and install it in the new cab. I had to cut an access hole and install a metal plate because this new cab had A/C.
The NP205 fits perfect under the cab with the new body mounts, it standard height. The body bushings were in horrible shape along with the sleeves were rusted away. I found 2 different sizes of pipe and cut it to length for the new sleeves. The donor cab was a 85' 2wd low hump.
« Last Edit: August 02, 2014, 09:49:43 am by sameold »
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: body change
« Reply #17 on: August 03, 2014, 08:14:18 pm »
So no raising of cab was needed?
Offline sameold
Re: body change
« Reply #18 on: August 04, 2014, 07:25:45 am »
no body lift was needed with bushings used from ebay 271391548136.
Offline pholliday1
Re: body change
« Reply #19 on: August 04, 2014, 09:40:18 pm »
Copy that
